b16a2 no spark/running rough
Okay car was running great I pulled out the box that the cruise control runs to and the car was getting no fire. Plugged it back in and it eventually started back up after 2 days but is surging fast at idle. Car will be running shut off and will not have fire again. I replaced the coil and the module inside the dizzy and cap and button.Still running obd2 dizzy rewired it just to make sure and rewired the vtec and the other wire that had to be added just because I didn't do the swap and wanted to know it was right. Plug wires are good, main relay is good.Codes: 36 TCS as I am running an auto p30 but has just came on when this problem started was running fine and wasn't throwing this code for 2 months. Code 14 aic valve replaced with 2 different ones that I know are good didn't change and still throwing the code. Code 10 forget what it was but changed it also same results. Help please this is my only car.
Still having this problem. I don't have much money and its getting expensive guessing. I'm going to get a new ecu tomorrow please reply if the ecu would not be the problem.
