fuel tank leak (pics)
Old Jun 16, 2014 | 03:15 PM
integra_101's Avatar
Default fuel tank leak (pics)
Where would it be leaking from. I want to fix it but need some insight. im not too good at finding leaks
thank you
Old Jun 16, 2014 | 03:29 PM
Prudz_lude's Avatar
Default Re: fuel tank leak (pics)
You are going to have to drop the tank to see where it is leaking from. Steps include, pulling fuel pump (removal of rear seats), pull fuel pump out, remove gas tank straps after draining fuel, inspect tank for hole. Possibly replace if the hole can't be fixed.
Old Jun 16, 2014 | 04:21 PM
yohan's Avatar
If it were me, I would hit the yard and grab a new gas tank and screw trying to patch it .... that's me though .. Advantage would be some hands on trial of learning how to remove it before tackling the real deal, then its a swap in swap out without having to mess with finding / fixing / waiting to dry .. what if the patch leaks again ...
Old Jun 16, 2014 | 07:37 PM
im getting a tank tomorrow from my friends parts car. i should get a new pump too. but ill have to get that later. I need this done ASAP.
my mechanic friend told me to run a quarter tank. he said its leaking at the center seam. so running a quarter tank will make it not leak.
Old Jun 17, 2014 | 06:41 AM
snobordboy's Avatar
Moderator
What good is a tank that you can't use all of it lol.
If the leak is indeed from the seam, swap in the better tank. If it ends up being something like a leaky gasket on the pump plate, just fix the problem.
As Prudz said, the only way to know for sure is to drop the tank and see where the leak is actually at.
Old Jun 17, 2014 | 03:08 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Did he drop the tank? I have seen various older model Hondas leak from rotted out fuel lines and leak all over the tank....
Old Jun 26, 2014 | 01:00 PM
no. but this is in a specific area where no lines are anywhere around
ive been running a quarter tank so far, and i haven't seen the leak anymore. so it is the tank
91cb7h23
Feb 10, 2013 04:13 PM
Hondaisok
Sep 27, 2010 09:30 AM
bbrian
May 16, 2005 05:34 PM
kaoss_11
11
Dec 9, 2004 08:29 PM
Zooper
22
Aug 15, 2004 09:45 PM
