Bogging issues...
Old Jun 15, 2014 | 07:25 PM
freddy chavez's Avatar
Default Bogging issues...
So i have a 99 ex civic and it bogs when i take of normal so i have to pump the gas pedal a bit for it to go.it only does it sometimes.so i did an oil change.spark plugs,wires.valve cover gasket set. Changed all that. But it still did it.so i read up a few threads and from the info i gathered it said to change the cap and rotor so i did. BINGO IT STOPPED BOGGING FOR A WHOLE DAY.So i tought i had fixed the problem but i was wrong,it started doing it again. What can it be ???should i replace the ignotion coil ?
Old Jun 15, 2014 | 07:52 PM
rspecturbo's Avatar
Default Re: Bogging issues...
do you have a check engine light on? if you do check the codes could possibly be a o2 sensor
nek9
Oct 12, 2006 02:59 PM
kjou2001
Jun 2, 2004 05:36 PM
krott5333
May 6, 2004 09:04 AM
scrapin777
Jul 29, 2002 01:39 PM
ahollowa
Aug 17, 2001 01:05 PM
