still smelling fuel
Old Jun 15, 2014 | 11:50 AM
jmanuel's Avatar
Default still smelling fuel
just did a basic tune up. cap rotor air filter plugs and wires pcv . still getting a fuel smell from tail pipe. smells mostly when cars first strted then slowly fades
Old Jun 15, 2014 | 05:39 PM
GhostAccord's Avatar
Default Re: still smelling fuel
Have you checked your fuel pressure regulator?
If you disconnect the vacuum hose on the top of the fuel pressure regulator and you can smell fuel in it. Then it's time for a new FPR.
Another thing you can try would be to pinch off the vacuum line to the FPR wile the engine is idling. The RPM should change when the vacuum is cut from the FPR. If it does not change you most likely need a new one.
It could be faulty and causing your car to run a little bit rich at idle/startup.
Old Jun 15, 2014 | 08:20 PM
jmanuel's Avatar
thanks ill go ahead and try that.
ill get back with what happens
Old Jun 18, 2014 | 01:00 AM
jmanuel's Avatar
ididnt smell any fuel from fpr vacuum hose?
Old Jun 18, 2014 | 02:03 PM
Did you also try pinching the vacuum hose? That is another test you can do.....
If the idle changes when you pinch off the vacuum hose the FPR is not working properly.
Old Jun 18, 2014 | 07:57 PM
jmanuel's Avatar
which is it? first you said i it doesnt change its not working?
likwidchz
Aug 25, 2008 09:48 PM
Exempt
May 28, 2005 05:24 AM
beaterman
Oct 13, 2003 10:33 AM
Rising sun #1
May 16, 2003 09:00 AM
technine
Jul 3, 2002 03:51 PM
