97 Civic turns over but won't start - No power to 2 injectors
So I bought a 97 civic last week with 250,000 on the body and 40,000 on a supposed rebuilt engine and tranny. I believe it the body and underbody/engine is super clean. Anyway, I had a misfire code. So I changed the plugs, wires, cap, rotor, and coil. They were all neglected. Now the car won't start. My buddy and I have been working on it for a couple days. With the new coil it gets so close it just doesn't get there. The last time we tried to start it we saw smoke and smelled gas. Any ideas?
Compression test, it will be a cold engine so lower numbers are expected.
High Energy Ignition (HEI) spark tester, check if you have spark and the quality.
Change the fuel filter and do a fuel pressure test.
Check air filter and make sure it isn't so clogged it's choking the motor.
When you crank the motor for a solid 15-20 seconds, pull your plugs and see if you smell gas on all 4 of them.
Even if you do, doesn't mean you have enough pressure to run the engine, the pressure tester will give you better indication.
Also ohm test all 4 injectors, the resistance should all be pretty close to each other.
Noid light test will tell you if they are getting proper signal.
HEI spark tester lets you rule out wires, coil and ICM.
If compression is good and all these things check out, the last two things it could be (besides bad timing) is a bad pressure regulator on the fuel rail or a bad ECU.
This should give you some direction on how to diagnose your problem.
If I missed something, hopefully someone else will pipe in with the feedback of it.
Good luck.
Good luck.
The plugs wires and coil 3 days old. It wouldn't start after I changed the cap and rotor. I have an intake with a brand new filter(also 3 days old) so it's not the filter either.
if you flooded the engine, you could have washed out the pistons, causing a loss of compression. try pulling the plugs and dropping a capful of oil down each well. https://www.hastingsmfg.com/ServiceTips/fuel_wash.htm
Good news and bad news. I got it to start and stay running. However, my # 2 and 3 fuel Injectors are bad. I went to the junkyard grabbed 2 off another civic. Same thing. Still starts and runs but really really rough. I pulled the harness of both and neither affected performance. However the outside two did.. I'm lost.
I'm not getting power to my #2 and #3 fuel injectors. It's been a long week. To make a long story short I bought the car last week it's a 97 civic dx. I replaced plugs wires, ignition coil, cap, and rotor. Then the car wouldn't start. So we sprayed starter fluid in the throttle body and it starts up every time. Went to the junk yard and picked up a couple injectors. Same problem. Just the #2 and #3 injectors aren't getting power. I'm lost and have no idea. Main relay, computer, wiring???
Only one thread per topic is allowed. 2 threads merged.
Sounds like the two power wires for the non-working injectors are broken somewhere between the main relay and the injector clips.
You need to test for voltage at the injector clips using a multimeter.
whoa. this car has more problems than youve described. list them all. then begin diagnosis on them all. do you have oil/coolant mixing? rent or buy a block tester, it is a simple test that checks for exhaust gas in your antifreeze. sounds like you may have been boned on this one.
Check your plug wires to see if you have them in the correct sequence!!!! Your car will still start, just really hard to get it started, plus two cylinders will seem like they are not working at all. Don't just "think" you did it right. Know you did it right.
Rubenjames25
13
Mar 6, 2014 11:55 PM
tikishow
Feb 28, 2007 08:52 AM
