98 integra ls swap questions
Old Jun 12, 2014 | 07:11 PM
Wkz1gg0a's Avatar
Default 98 integra ls swap questions
Now I know most of you might flame me for this but I have been reading multiple forms on swapping a b20b into an integra but every form has something different to say.
I have a 1998 Integra DB7 automatic this is my work/daily I am not building this car but my current b18b1 has lost compression in cylinder 3 (bad rings). Once again its my daily work vehicle.
So far ive read its a direct plug and play others say its not.
what I do know is that I will have to do
- swap the throttle body/intake manni
- do a crank sensor bypass
- swap over my ac and powersteering pumps with brakets
the car is a 98 so im guessing its a obd2a correct me if im wrong.
now this is where im confused some people say I need to swap the engine mounting braket by the timing cover and swap my crank pulley whislt other never mention this.
Other people also say I can not use my b18b header because of clearance issues.
What I do want to know is there a real write up on this swap?
Am I missing anything? Do I really need to swap the crank pulley and mounting bracket.
The car is registered in NY
once again its a Daily Work vehicle not a high end build I have my Prelude for that.....
Old Jun 12, 2014 | 11:40 PM
Kris EG Hatch's Avatar
Default Re: 98 integra ls swap questions
As far as I see none vtec b series link up to none b series it's basically the same motor as your b18b1
Old Jun 13, 2014 | 05:52 AM
B_Swapped93's Avatar
just swap the itm/tb as being an auto there may be a few issues, there may not I'm just thinking back to d-series engines. as for the CSB why ? just get a usdm "low comp" b20b if that's not an option look up crank sensor bypass. ps pump/brackets should be the same but never hurts to swap them over.
Old Jun 13, 2014 | 06:16 AM
Wkz1gg0a's Avatar
Im getting a JDM B20B for $250 with paper work from an importer therfore It doesnt have a crank sensor
arent most B20 engines out of a auto vehicle?
Old Jun 13, 2014 | 08:27 AM
NVturbo's Avatar
O.G. triple O.G.
Most were mated to an automatic transmission. There were some 5spd CRVs as well.
Cjs_slowkey_ej6
Aug 21, 2015 06:59 AM
quiocho8o8
Nov 11, 2009 04:52 PM
balili89
Feb 18, 2008 08:39 PM
