help with tuck harness install
Old Jun 12, 2014 | 02:02 PM
$MIKE$'s Avatar
Default help with tuck harness install
hey all need some help here im missing something simple just cant figure it out.
I just got my rywire tucked harness in the mail and now I am having trouble envision how this thing is going to hook up.
it comes in two pieces one with all the connectors the motor components easy enough.
then it splits into a sub harness with 4 connectors and 6 loose wires.
I am assuming the applicable connectors is present for my chassis for the 3 connectors as the 4th one connects to a plug from the engine harness.
now rywire website says the 6 loose wires get taped or connected to the old ecu plug, so am I corrected in assuming that that oem ecu plug must remain in the car and cannot be removed?
so what portion of the old oem harness get removed?
I understand that pretty much everything from the engine harness must be unloomed and separated to accommodate the new harness.
Old Jun 12, 2014 | 02:04 PM
$MIKE$'s Avatar
Default Re: help with tuck harness install
IS this right?
circled in red goes to ecu
green is a dead plug
black will plug in to Driverside shock toweer
yellow gets taped into the old ecu harness although no ecu will be connected to it.
B18c1turboedEK
Jan 31, 2010 03:15 PM
asigler
Jul 22, 2009 10:59 AM
nello a.
Dec 24, 2008 12:20 AM
