Coolant leak on 2002 accord
Old Jun 12, 2014 | 01:55 PM
free_money's Avatar
Default Coolant leak on 2002 accord
I had my timing belt replaced about 3 months ago and luckily my camshaft snapped and bent all the valves in my engine shortly after the new belt. My wife's uncle put in a rebuilt head and camshaft but managed to break the knock sensor in the process. I replaced the knock sensor and while doing that, I noticed a coolant leak coming from the coolant pipe where it connects to the water pump. I figured the coolant pipe possibly needs a new o ring and was wondering how do I replace these. I don't see any bolts holding it in place to the back of the water pump or to the thermostat housing.
Old Jun 12, 2014 | 02:21 PM
holmesnmanny's Avatar
Default Re: Coolant leak on 2002 accord
There are bolts holding the pipe to the block. Remove the thermostat housing assembly and the bolts holding the pipe and it'll pull right out.
Not sure why you said "luckily my camshaft snapped and belt all the valves". Nothing lucky about that.
Old Jun 12, 2014 | 02:27 PM
free_money's Avatar
I was just being sarcastic about it lol
Does anything else have to be removed to get the coolant pipe out of the way other than removing the tstat housing? I definitely dont want to break the knock sensor cause that was $118 to replace. Plus it seems like the oil sensor might be in the way.
Old Jun 12, 2014 | 08:25 PM
http://www.hondapartscheap.com/auto-...5-speed-manual
Ok there's a bolt at part number 20.
There is a hose that attaches closest to that bolt at part 2.
Then there is the water pipe to heater hose at part 4.
You will probably be best served buying all new hoses. The water pipe to valve hose will be especially tricky to remove.
You may be able to get away with just removing the bolt and pulling the pipe enough to get the new oring on but you run the risk of causing a leak in the hoses or even them simply tearing.
Old Jun 13, 2014 | 12:48 PM
free_money's Avatar
Thanks so much for your help!! Also, are there any gaskets when I remove the thermostat housing and water outlet that should be replaced?
Ainsworth03
Honda Civic (2006 - 2015)
Jun 27, 2014 12:56 AM
krysted9354
Jan 27, 2009 03:34 PM
wmertz187
Apr 25, 2007 12:38 PM
my97accord
Jan 31, 2005 05:20 AM
vtec_kman
Mar 23, 2004 09:41 AM
