tire hitting pinch weld in fender
Old Jun 12, 2014 | 12:48 PM
Integra99's Avatar
Default tire hitting pinch weld in fender
How do all you slammed/stanced/meaty tire people prevent this besides raising the car. Its on my integra with 215/45/16 tires. Im not super low either. Any help on what you did
Old Jun 12, 2014 | 12:55 PM
Fliptard's Avatar
Default Re: tire hitting pinch weld in fender
cut slits in it ever 1' or so and bend them where-ever the wheel hits.
Old Jun 12, 2014 | 02:32 PM
TunerN00b's Avatar
That should be
cut slits in it every 1" or so and pound it flat.
Because cutting every foot won't be much help...
Old Jun 12, 2014 | 02:37 PM
Fliptard's Avatar
opps, my bad. lmao. every 1 INCH
Old Jun 12, 2014 | 03:01 PM
Integra99's Avatar
Would doing it that way cause any structural weakness or anything?
Old Jun 12, 2014 | 03:05 PM
Fliptard's Avatar
it may weaken that area, but not enough to actually do/cause any damaged.
Old Jun 12, 2014 | 03:51 PM
B_Swapped93's Avatar
I recently did it to get more clearance, not ill affects if you bend it over just do a few cuts then smash it with a hammer.
Old Jun 12, 2014 | 04:08 PM
Garage_Spec's Avatar
DO NOT CUT IT! Just pound it over and perhaps use a torch to heat it just enough. I promise you that your car will lose ridigity if you cut the seams.
Old Jun 12, 2014 | 04:25 PM
Integra99's Avatar
I had a couple people say don't hammer, not on here and some say to grind it.
Old Jun 12, 2014 | 04:42 PM
I actually only live an hour away from you haha, best thing would be to spot weld after you hammer it over to reinforce it a bit.
Old Jun 12, 2014 | 04:43 PM
what do you do with you car ? stance lyfe... DD or light tracking(time attack) you could cut it off completely then weld it once it's flat. but cutting slits in it then hammering it over won't hurt anything. Those who say it will make a noticeable comprise are the same ppl that say "you need a F7 subframe brace" when all they do is auto x and think they're pro race car drivers.
Old Jun 12, 2014 | 04:48 PM
So Spoon doesn't know what they're doing either do they? Lol
Old Jun 12, 2014 | 04:54 PM
you're NOT separating the weld simply bending it for a section of 1ft heck holes in the floor are a bigger compromise again you're NOT splitting it or cutting it just 2 slips the hitting it to the outside.
WTF does spoon have to do in this thread, where was it even mentioned
Old Jun 12, 2014 | 05:01 PM
You can cut up your car however you like, I'm simply guiding the OP in the correct direction. Not how people THINK it should be done and it MIGHT be okay. If you've ever been to any track OR autocross and seen prepped Hondas you would see how it's done, therefore the Spoon reference was made because I've seen a shoot of some of there cars that were treated the same way. Google helps quite a bit.
Old Jun 12, 2014 | 05:07 PM
I'm waiting for your EXPERT proof that it makes a notable difference, I better go tell my fabricator to stop doing K swaps as it doesn't use the OEM mount/location(s)on the pass side it's just "screwed in".
PROOF or GTFO, my proof we have several cars that have altered rad supports/front bulkheads to fit turbo set ups and I'd love to see you tell them they're hacking their cars up, when they made it to button willow raceway for GTA:SLB.
Old Jun 12, 2014 | 05:11 PM
Lol whatever floats your boat.
Old Jun 12, 2014 | 05:13 PM
Old Jun 12, 2014 | 05:19 PM
I never said it wouldn't work, but it doesn't work as well as it could, and a radiator support is slightly different than the pinch welds on a section of the car that holds a lot more load. Keeping poking your stick, you're wasting your time..
Old Jun 12, 2014 | 06:37 PM
jdmjunkieXL's Avatar
i didnt have to cut anything. I just hammerd it flat use a baby sledge
Old Jun 14, 2014 | 07:58 PM
Just bent the pinch weld on my car today. Zero cutting, using only a standard carpenters hammer...
gnozahs
Jun 19, 2014 10:50 PM
mish__
Suspension & Brakes
Mar 3, 2013 12:08 PM
iH8RICERZ
Jul 31, 2006 02:34 AM
B18ls*RAYON
Feb 1, 2006 04:40 PM
deviant1
45
May 24, 2004 10:44 AM
