NEED HELP! Tranny Fluid Fill Bolt Seized, where is VSS hole? EF 2WD Wagon
Old Jun 12, 2014 | 10:53 AM
D7KWagon's Avatar
Default NEED HELP! Tranny Fluid Fill Bolt Seized, where is VSS hole? EF 2WD Wagon
Hey, topic title says it all.
Fill bolt is seized on my tranny and just did a CV Axle job. I was told that you can fill it with through the VSS, or vehicle speed sensor, hole on the tranny, but I've searched forums and no one seems to have a current pic of some schematics.
This is a time sensitive repair so any quick help is greatly appreciated,
Thanks so much!
Old Jun 12, 2014 | 10:55 AM
David_S's Avatar
Default Re: NEED HELP! Tranny Fluid Fill Bolt Seized, where is VSS hole? EF 2WD Wagon
Follow the speedometer cable to the transmission. Where the cable goes in is what they are talking about. On 92 and up I believe that this is an electrical sensor mounted there instead. Filling it there you could actually over fill it though so be careful.
Old Jun 12, 2014 | 11:06 AM
F22Master's Avatar
Put a 17mm box end wrench on the fill bolt. Hit the end with a heavy rubber mallet. Fill normally.
Old Jun 12, 2014 | 11:40 AM
RanCRX's Avatar
If you can't get the fill bolt out with a 17mm and hammer then the VSS should be at the top of the tranny by the firewall, at least my b16's vss location. From there, you push up the boot, take out the pin holding the cable, remove cable, remove 10-12mm bolt, and speed sensor can be pulled up and you can fill in there, only problem is, don't overfill or underfill. GL
Old Jun 12, 2014 | 01:23 PM
xprometheusx's Avatar
hmm no one knows what a impact is any more?
Old Jun 12, 2014 | 02:18 PM
24TEN's Avatar
PHANTOM MENACE
Might not have one, or might not even be able to get it in that area nicely.
Old Jun 12, 2014 | 05:22 PM
Riceburner247's Avatar
Using an impact on a seized fill or drain bolt is not a good idea. Nothing complicates the problem more than shearing the head off and leaving the bolt in place.
Old Jun 14, 2014 | 11:57 AM
Tyson's Avatar
This.
Old Jun 14, 2014 | 12:01 PM
F22Master's Avatar
JUST like this. Then hit the bottom, coming from the left, to turn the bolt Counter-clockwise.
Old Jun 14, 2014 | 01:08 PM
Tyson's Avatar
I suggest a 6pt end wrench tho.
ElCivic89
Apr 21, 2011 06:43 AM
d4rksid3
Jun 21, 2007 06:36 PM
pocketviper
Jun 3, 2007 05:36 PM
REDBARON
27
Jun 6, 2003 03:22 PM
araknis
Apr 10, 2002 03:38 PM
