Main Relay - No ground at pin #3 ... any clue ?
Old Jun 11, 2014 | 08:23 PM
mycho's Avatar
Default Main Relay - No ground at pin #3 ... any clue ?
Hi Guys,
My Integra started an intermitent problem this weekend.
It gradually, over last 4 days, became a permanent issue.
The symptom was for the fuel pump not to prime during the ignition cycle.
I troubleshooted the main relay and found that I have no ground at pin #3.
This ground is supplied directly by the ECU.
I tried 2 P28 ecu (both known to be working before last weekend) --> no change.
If if add a jumper between Main relay Pin#3 and a good chassis ground, fuel pump is priming and car starts like a charm.
Any idea what could cause the ECU to not provide this ground ?
Car: Integra 95 race car
Engine: B18C
ECU: P28 - socketed
Old Jun 12, 2014 | 04:04 AM
mycho's Avatar
Default Re: Main Relay - No ground at pin #3 ... any clue ?
ok nevermind ... found a broken wire inside the insulation between G101 and L/H firewall connector
Old Jun 12, 2014 | 09:38 PM
HerbNRacer's Avatar
Nice work !!
Markalark
Sep 22, 2013 03:32 PM
DDTECH
May 11, 2012 08:42 PM
lledcomp
Apr 5, 2007 06:20 PM
Project91Hatch
Sep 1, 2006 01:44 AM
2 0 3
Jul 30, 2006 05:36 PM
