97 Gsr idling problem
Old Jun 10, 2014 | 06:01 PM
vtecwreck's Avatar
Default 97 Gsr idling problem
What's going on Honda-tech. I recently swapped my 97 gsr motor into my 95 integra shell. When we started it, it was idling from about 1.5rpm to 4-5rpm.. We cant seem to find the problem. Any suggestions?
Old Jun 10, 2014 | 07:17 PM
vtecwreck's Avatar
Default Re: 97 Gsr idling problem
Bumpppp
Old Jun 12, 2014 | 03:50 PM
duh702dc2's Avatar
Check the radiator to make sure you bleed it. Test the TPS. Look around for a vacuum leak. Clean the throttle body. Clean the fitv with carb cleaner if the idle raises then drops that's probably your problem. If not then it could be wiring or map sensor and tps sensor are switched an didn't notice.
Hope this helps pal
HarosGSRek
Engine Management and Tuning
Jul 1, 2009 10:58 AM
818blue818
Jan 6, 2009 02:59 PM
vietxdragon
Jan 5, 2009 08:04 PM
19992civichatch
Mar 15, 2007 07:33 PM
