Gsr eg hatch vtec not working and fuel issues
Old Jun 9, 2014 | 11:39 AM
redlineEGhatch's Avatar
Default Gsr eg hatch vtec not working and fuel issues
so my friend and i just swapped a gsr into an eg hatch and were having problems with it burning too much fuel even after adjusting the pressure with a fuel regulator. Also just got done wiring vtec with the rywire vtec subharness kit and vtec still not working. We do have code 21 which is spool valve/vtec solenoid but when checking the resistance on the solenoid its within spec. Also to mention i have a p72 ecu chipped and stock gsr manifold with the secondary butterflies removed and no iab, would this affect its driveability? The motor seems to run fine powerwise but the mpgs are horrible and cannot get vtec working. Any input would be helpfull, thank you in advance.
Old Jun 9, 2014 | 12:11 PM
ElectronBlue00's Avatar
Default Re: Gsr eg hatch vtec not working and fuel issues
Try this.
Old Jun 9, 2014 | 12:40 PM
The valve itself had 17 ohms. The wire has .2 ohms and there isnt anything in those screens. Pretty sure also that the .2 is because of my meter so the resistance in the wire going to the ecu is 0 witch is what you want.
Old Jun 9, 2014 | 12:52 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
You likely mixed up the Coolant temp sensor and VTEC plugs. Try swapping them.
FYI, if VTEC is set at the stock 4400RPM, you likely won't hear VTEC crossover when you do get it working.
Adjust the FPR back to factory (GSR) spec when you get it all working. Or use a stock GSR FPR.
The IAB delete will make the engine feel a bit weak down in the lower RPM range.
Old Jun 9, 2014 | 02:01 PM
Uhm that doesn't make sense. I have a rywire vtec subharness. There is no mixing that up. You plug it to the solenoid and the oil switch and then straight to the ecu. I did that all the test check out and still a 21 code. Also my
Fuel pressure is at 42 witch is within stock gsr fuel pressure.
Old Jun 9, 2014 | 02:10 PM
nub's Avatar
nub
Try a stock ecu. Your "chipped" ecu likely has a generic junk base map on it.
Old Jun 9, 2014 | 06:07 PM
I guess I'll try that. Should I go p28 or p72?
Old Jun 9, 2014 | 06:14 PM
nub's Avatar
nub
P28 is for a D16Z6, P72 is for a B18C1.
Old Jun 10, 2014 | 06:57 AM
I cut the lead to stop reading the chip and went back to a stock ecu and it still threw the same code 21
Old Jun 10, 2014 | 07:00 AM
Former User's Avatar
Did you short test the wire?
Old Jun 10, 2014 | 10:09 AM
Wire is good. Wired correctly. Solenoid works. So all that's left is the ecu right?
Old Jun 10, 2014 | 10:15 AM
To answer this^, you'd need to describe the troubleshooting that led you to these conclusions:
Old Jun 10, 2014 | 11:39 AM
I Already have. I tested the solenoid itself. Did the resistance test I got 17 ohms witch within spec. I ran power straight to the solenoid with a jumper wire, it
Clicked and was working. I test the resistance in the wire going to the ecu from the solenoid. Zero resistance
That's good. I tried a stock ecu with it and still got code 21
Old Jun 10, 2014 | 11:41 AM
No short test?
Old Jun 10, 2014 | 03:27 PM
B serious's Avatar
is this a JDM solenoid?
Old Jun 10, 2014 | 04:37 PM
nub's Avatar
nub
This statement for me raises a flag. Zero resistance? You either measured it wrong or you're throwing happy thoughts out there.
Whatever wire you used of that length is going to have some resistance.
As Ron is hinting, you should also check for continuity to ground with the ecu A connector and the spool valve unplugged.
Old Jun 10, 2014 | 05:43 PM
Ok .2 resistance but I don't know if that's my meter is a little off but whatever it's got .2 ohms in the wire. As for is it a jdm solenoid I have no clue.
Old Jun 10, 2014 | 05:46 PM
Your gonna have to explain a short test and I'll do it in the morning.
Old Jun 10, 2014 | 05:52 PM
Short test - touch one meter probe to the wire and the other probe to body ground with meter set to read continuity or resistance.
Your Name
11
Jan 17, 2010 08:07 PM
kraig8
Dec 18, 2005 02:10 PM
Axemurderer23
Aug 7, 2004 08:36 AM
