eg/eh gsr mounts?
I bought a eh HATCH with a GSR swap and the previous owner told me it needed "a couple of mounts" I know it needs a lower front trans torque mount but what else is there? actual names please! not just "the one connected to the block" im not stupid, but im not a genius either, but I just don't wanna mess anything up. please help!! and no hate please!
check the faq in your car section or see if this helps:
https://honda-tech.com/forums/hybrid-engine-swaps-18/definitive-guide-gsr-eg-swap-2976738/
There are 3 main mounts that support the engine then 2 in the front on either side that act as "torque mounts" to keep the engine from rocking too much. The rear chassis mount, passenger trans mount, and driver's mount can be from a 92-95 Civic or 94-01 Integra. The rear t-bracket from trans to mount needs to be from a 94-01 Integra or 94-97 del sol VTEC. The driver's side mount can be a 2-bolt or 3-bolt style, but needs the matching bracket that bolts to the block. The driver's side torque mount bracket need to be from a 94-01 Integra, 94-97 del sol VTEC (needed to keep Civic A/C), or B20 CR-V; the pass side torque bracket needs to be from a 94-01 teg or 94-97 del sol VTEC .
We can't tell you **** beyond that w/o pictures of your current mounts.
brharris777
Feb 2, 2011 08:27 PM
