crx stage rally footage
Stage 1 of last weekends Rally America STPR in Pennsylvania. 91 crx with ZC engine and tranny with quaif LSD and Mfactory 4.9 final drive. Was a rough stage but we managed to get 1st in Group 2. Unfortunately the clutch blew apart on stage 3. Had a blast though, fun rally. Shaved 1 minute off our previous stage time 2 years ago, due to the new final drive.
Hotbits rally suspension out of Canada. A standard coilover with flat helper springs. Adjustable comp and rebound and fully rebuildable. They make rally setups for pretty much every car out there and last about 10 rallies until their seals are worn out.
OK, thanks. Here's all of the photos that I have. The cage was built to the standard FIA rally cage documents. After the build, the cage was drilled to verify tube thickness, then Number stamped and issued a logbook at its first rally. http://s1227.photobucket.com/user/se...?sort=3&page=2
Thanks for pics!
Looks like massive amounts of fun.
Can you tell me the thought process of the extra A pillar down tube and why there ended up being a kink in it?
hope that helps - Sean
flat-blk-HB
25
Jun 2, 2004 04:00 PM
