H22A ek coolant issue !!!
Old Jun 8, 2014 | 12:15 PM
Cmanning816's Avatar
Default H22A ek coolant issue !!!
I have no leaks at all no drips nothing like that but my car is eating antifreeze any ideas all I can think is head gasket
Old Jun 8, 2014 | 01:03 PM
grumblemarc's Avatar
The Grumpiest
Default Re: H22A ek coolant issue !!!
Pressure test the system. If you're not leaking then you're burning.
Old Jun 9, 2014 | 05:11 AM
HiProfile's Avatar
Technically it only drinks antifreeze.
Most of the time hoses & seals are to blame, not the headgasket. Most leaks aren't directly to the ground, and it takes 10-15 minutes to pressurize the system at idle so they're usually hard to find. In reality a steady drip will happen while driving, and if it doesn't evaporate on a hot part it will be shed off from movement/vibration. Sprinkling baby powder near all hoses & seals will help, any area that gets a drip will change color. Keep in mind a lot will fly off if you do anything but low-speed driving.
I recently had a water pump that had a heavy drip because of a reused seal & missing bolt, and it only leaked when the motor was hot. When I pressure tested the motor, I didn't lose anything. I recommend doing leak tests when the engine is warm, but cool enough to have lost most pressure.
single_slam
Feb 3, 2014 01:22 PM
jhines1211
10
Jul 11, 2011 05:07 PM
MarkM01
Honda Civic (2001 - 2005)
Apr 10, 2011 04:21 AM
BLU CIVIC
11
Dec 12, 2010 04:12 PM
97akwerd
Jul 30, 2005 08:43 AM
