97 Civic HX - overheating
Old Jun 8, 2014 | 07:20 AM
@HondaProbs's Avatar
Default 97 Civic HX - overheating
Alright, so I'm new to the forums everyone.
I have a 1997 Honda Civic Hx 4 cylinder 1.6L non v-tech with a overheating issue. A couple days ago my radiator cracked and started smoking from under the hood. I replaced the radiator. Still overheating and fan won't kick on. I then replace the relays. Why change just one? I replaced them all. Fan worked, then stopped a mile down the road and started overheating again. I used the paperclip method to bypass the relays and the fan kicked on constantly when the cars running So the fan and motor are good as well. Changed the fan switch. Changed the coolant temperature sensor. Fan kicks on now but only at like 3/4 of the way up on the guage.
Any ideas Everyone?
Old Jun 8, 2014 | 07:39 AM
Former User's Avatar
Default Re: Really need some help here;
Please read the forum Rules sticky.
This vague, uninformative thread title is not allowed. You MUST summarize the tech question/problem in your title -edited.
Bleed the cooling system, and then go from there.
And never let the the temp gauge needle rise above the halfway mark.
Old Jun 8, 2014 | 12:44 PM
Default Re: 97 Civic HX - overheating
Ive already bled the cooling System. And it clearly states 97 Civic hx overheating... but thanks, i was thinking more of the thermostat seeing as That's the only thing i haven't replaced when it comes to the cooling System.
Old Jun 8, 2014 | 01:41 PM
How? Give details.
Clue in. That's my edited thread title.
Then replace it and properly bleed the cooling system.
Old Jun 8, 2014 | 01:50 PM
I put the front end of the car at an angle on wheel ramps and took the radiator cap off letting it idle for about a half hour to bleed air out of the System.
Old Jun 8, 2014 | 01:52 PM
Were the reservoir and radiator topped off with coolant? Did the radiator fan turn on twice during the procedure?
dyablo
Sep 10, 2015 01:37 PM
jodyboy
12
Aug 15, 2012 09:39 PM
jeagle
Honda CR-V & Element
Aug 6, 2012 08:24 AM
mika
Aug 8, 2004 05:00 PM
