98 honda civic wiper motor failure
Old Jun 7, 2014 | 11:23 AM
namingwaysway's Avatar
Default 98 honda civic wiper motor failure
Hi everyone!
I have a problem with my 98 honda civic's wiper system. Originally the wipers would not shut off. I turned them on one day, and found that they stopped responding to the switch at all. I had to pull the fuse to get home. I read that it was almost certainly the wiper motor, so, I picked up a new one and replaced it.
After replacing the motor, they no longer are stuck on, but they do not work at all. The fuse is back in, and I actually replaced the wiper switch because it felt broken. But that did not help. I can hear the relay (?) Clicking at different speeds when I put it in different modes, but the wipers do not move.
I am curious if there is a set position that I need to leave them in after I put it back, and maybe that's why? But I'm stumped
Old Jun 7, 2014 | 12:30 PM
grumblemarc's Avatar
The Grumpiest
Default Re: 98 honda civic wiper motor failure
Is the motor even getting power? Did you check that before you swapped out motors?
Old Jun 8, 2014 | 06:54 AM
Former User's Avatar
Did you buy a new or used wiper motor?
Old Jun 9, 2014 | 01:04 PM
The wiper motor was getting power. Or at least before I changed it - the wipers would not stop without pulling the fuse. I didn't check the voltages, but I will again.
I purchased a remanufactured motor.
I have also noticed some strange bugs with the blower for the AC - I know it may be unrelated, but could there be a short in the electrical system that caused the original problem?
Old Jun 9, 2014 | 01:17 PM
Run power and ground wires directly from the battery to the wiper motor. Does it run?
Old Jun 9, 2014 | 04:49 PM
Well, an update - I had an extra motor, and changed them. It runs properly now except it stops dead center of the windshield. It does this on all cycles, but wipes the whole glass. I think the problem was just the motor - I'll return it.
I don't know how the thing figures out home, so, I have no idea what to check next, any ideas?
Old Jun 9, 2014 | 04:59 PM
The motor has a separate park motor that may be bad. Other possibilities are a bad park wire between the motor and ICU or a bad ICU. My bet is on a bad park motor.
Old Jun 10, 2014 | 07:53 AM
That's what I've also read from other places, so I'm going to return it and try a *THIRD* motor -.-
Old Jun 17, 2014 | 01:54 PM
Alright, I replaced the motor again, and it seems that the parking problem is not fixed. I also started having problems with my dome light and door locks being flaky. Half of the time they work, and half of the time they do not. I read that the ICU also controls these components. Since it is flaky, do you think it is bad, or could there be a grounding issue somewhere?
Old Jun 18, 2014 | 05:25 AM
You need the service manual.
Start by double checking the wiper motor installation. Proper installation involves aligning the motor and link in the park position.
pityocamptes
Aug 9, 2014 09:03 PM
lisitpc
Jun 16, 2013 11:42 AM
Olias
Nov 22, 2008 02:36 PM
nbcivic
Oct 5, 2007 01:14 AM
pom69
Dec 7, 2004 12:53 PM
