Water leaking into trunk
Hi.
Would like some help with finding where the leak comes from.
A while ago, I found out water was leaking into my trunk. There was water leaking from the taillights. I changed the piece if foam between the taillights and the body.
It rained again today and I found water in my trunk again. The taillight area is dry.
So there must be another place leaking
Any advice as to where to look into?
I don't have an antenna. I shaved the antenna on my car.
Your first post tells me that it's most likely the seal of your tail light. I had same the issue with water leaking into the trunk after I had a minor accident in my old 99 GSR that required a repair and removal of the tail light. Everything was great after it was repaired until it rained. I took it back and they simply removed the tail light and used a thin layer of sealer, not sure what kind though, but it never leaked again. My best guess would be a glass sealant like the type used for windshields? Hope it helps and good luck.
