044 fuel pump wire help
Old Jun 6, 2014 | 10:06 AM
eg:R's Avatar
Default 044 fuel pump wire help
What 12v trigger wire can be used when putting the 044 in the front engine bay in between the filter and rail. Will be using a relay . Will this work with a walbro 400 or 450lpm in the tank? Since the walbro will be pushing faster than the 044 pulling ??
Old Jun 11, 2014 | 01:55 PM
eg:R's Avatar
Default Re: 044 fuel pump wire help
No one done this before??
Old Jun 12, 2014 | 05:33 PM
$MIKE$'s Avatar
Depends on the power you are pushing 1walbro 400 should be enough.
If you want run a 320 plus 044 but it's kinda over kill. I don't know your fuel or power level but there are a lot of options for fuel pumping. Z
As for your trigger you can pull it from the top of your oem pump hanger. Then wire it to a big relay
Old Jun 16, 2014 | 07:15 AM
eg:R's Avatar
I'm planning to run e85 and make over 500hp.
boostedefhatch
May 4, 2010 03:00 PM
crxfreak1117
Aug 15, 2009 06:09 AM
5lugSlug
Audio / Security / Video
14
Sep 24, 2005 12:06 PM
servion
Jun 3, 2004 07:54 AM
EF8SIR
Mar 19, 2002 05:11 AM
