Hard to shift from 5th to 6th
Old Jun 6, 2014 | 08:56 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Hard to shift from 5th to 6th
Hard to shift from 5th to 6th. But not from 6th to 5th.
This first happened back in Jan, and has gotten worst to where nearly all the time, I can't go from 5th to 6th.
So what I have done is to go from 5th to 4th, then to 6th, while holding the clutch down. This movement allows me to go into 6th gear.
I can also just go from 4th to 6th with no issues.
Other suggested that perhaps the shift bushing may be worn.
Please take a look at this pic. Do you visually see anything (else) wrong?
The bushings are the letter A, is that correct?
Also, because this is a used car and I don't know what it looks like new. There is a tiny gap in rubber part of A, right side. Is that the cause you think? It's the bushings?
TheMidnightLude
Apr 4, 2011 04:32 AM
pprowler6
Jan 16, 2007 08:37 PM
spiderseth
Nov 10, 2004 04:17 PM
