1996 Honda Accord Coolant fan control module
Old Jun 5, 2014 | 08:04 PM
rriznyk's Avatar
Icon6 1996 Honda Accord Coolant fan control module
My 96 2.2L Honda Accord LX coolant fan does not turn on anymore once the engine shuts off. The fan used to spin regularly upon turning off the ignition until the engine cooled. We live 6 miles uphill from the ocean in Hawaii and the engine does get quite hot after this climb. Is there some way to check the coolant fan control module behind the glove box to verify if it is operational? I tried jumping ECT switch B wiring, ignition on, that controls the fan with a paperclip but nothing happened. Is it possible to jump wire the fan control module itself to get the fan to spin?
Raymond
Old Jun 5, 2014 | 09:37 PM
holmesnmanny's Avatar
Default Re: 1996 Honda Accord Coolant fan control module
First apply direct battery power to the fan motor to be sure the fan motor itself isn't blown. Is it really hot where you live ? The fan shouldn't regularly come on after you turn off the ignition unless it's really hot out.
Old Jun 7, 2014 | 08:05 AM
Lost Again's Avatar
Also note - if you are jumping thermo B (upper hose to engine) - DO NOT turn the ign on. You do this test with the ign off.
Thermo B only has control of "the fan" when the ign is off.
Old Jun 7, 2014 | 12:26 PM
rriznyk's Avatar
Old Jun 7, 2014 | 12:32 PM
rriznyk's Avatar
I know the fan motors are working as I jumped the ECT switch A and both fans turned on. Also, with AC turned on and ignition switch on, both fans spin. The coolant fan as a rule always turned on after climbing the hill back home when the engine was shut off. All of a sudden it no longer happened. The engine even overheated once and the cooling fan did not turn on even though I could hear the water boiling in the radiator.
Raymond
Old Jun 7, 2014 | 01:01 PM
rriznyk's Avatar
I tried jumping the thermo switch B with ignition off and the fan motor did turn on. Eureka! Thanks for the tip. I think I've isolated the issue to a defective thermo switch B.
Raymond
Old Jun 7, 2014 | 01:11 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
I was going to say if you needed a module they had a half off sale at the yard today and they had one in good shape with almost everything there
Old Oct 18, 2015 | 08:25 AM
joezmam367's Avatar
Care to share a link?
Jason Galatz
Aug 8, 2013 03:28 PM
1989 Honda Accord
Jan 3, 2013 06:48 PM
zrsm9
Aug 13, 2010 08:13 AM
riztsi
Dec 12, 2004 06:46 PM
