B18c rattle sound! WTfork!!!
Old Jun 5, 2014 | 07:29 PM
duh702dc2's Avatar
Default B18c rattle sound! WTfork!!!
Ok so motor is a JDM b18c type r an I had this odd sound in the head so I did a valve adjustment and now the valves are quit but I have this rattle sound that is loud on cold starts an as the motor warms up it gets a little less but not gone. The sound is at idle and when you rev the motor. I thought it could be the LMA ( lost motion assembly) but I pulled the cover an pushed on all them an they seem fine none got stuck down. I did this test with the cams in just pushed on the middle lifter.
The sound actually sounds more in the can gears or near the timing belt. It isnt a tick its like metal ratteling sound.
If anyone can help a brother out I'd appreciate it.
Old Jun 5, 2014 | 09:58 PM
holmesnmanny's Avatar
if it sounds like rocks rattling around in a can its a bearing...possibly tensioner bearing ... something timing side
Old Jun 6, 2014 | 08:40 AM
duh702dc2's Avatar
Default Re: B18c rattle sound! WTfork!!!
Is that the only bearing near the timing belt? I used a stethoscope to listen to every inch of the motor an couldn't hear anything. Never got low enough for the tensioner though.
Old Jun 6, 2014 | 04:12 PM
several bearings ... oil pump, water pump, balance shaft, if noise is on top could be alternator bearing, ac comp bearing if you got one, ps pump bearing if you got one, i had a tensioner bearing fail before and the noise was tough to track down but the more i listened it came clear it was somewhat low
i had overtorqued my tensioner adjusting bolt which i think made it fail prematurely...the other bearings are more or less less likely to go bad
duh702dc2
Jun 29, 2014 07:10 PM
duh702dc2
Jun 12, 2014 04:50 PM
DeCoY
May 27, 2009 01:18 AM
teh hatton
Jul 17, 2007 09:45 AM
Quiks66
Aug 6, 2004 10:25 AM
