Crank@ TDC/ Cam rotated when torqued
Old Jun 5, 2014 | 07:09 PM
civicboy420's Avatar
Default Crank@ TDC/ Cam rotated when torqued
Ok guys, so I'm almost finished rebuilding my D16Z6. Before I installed the head, I had to rotate my crank one tooth to TDC, now the notch lines up on the oil pump with the crank pulley gear. I then bolted the head down to spec. laid down the camshaft to TDC and torqued the rocker assembly to spec. I noticed the cam rotated two teeth away from TDC. The only thing I could think to do was rotate it back by hand, which I did. My question, did I screw up somewhere or is it normal for it to rotate like that when torquing the rockers down? Do I just install the timing belt and Adjust the valves and be good to go? Thanks in advance.
Old Jun 5, 2014 | 07:54 PM
F22Master's Avatar
Default Re: Crank@ TDC/ Cam rotated when torqued
Yes, thats fine, just line it back up and put the belt on.
Old Jun 5, 2014 | 07:55 PM
Thanks
Old Jun 5, 2014 | 09:13 PM
Looked online turns out my chilton was wrong, I torqued the rockers down wrong went outside in, I hope I didnt screw anything up
foolsforever
11
Aug 9, 2018 05:08 PM
goota
Aug 22, 2009 07:38 AM
Civicman86
Jun 22, 2006 10:01 AM
JRciv
Nov 22, 2004 01:58 PM
brockscivic
Jul 6, 2004 10:07 AM
