Stock Radio Code, Can I get it while the radio is still connected?
Old Jun 5, 2014 | 06:03 PM
jetlife's Avatar
Default Stock Radio Code, Can I get it while the radio is still connected?
OK, so my Mother gifted my son her 1990 Honda Accord EX.
Great car and just over 100K too.
It lately began stalling in hot weather.
I shorted out the Wires near the passenger kick panel, and checked the code.
I got 15, Engine output signal.
I ordered OEM 7026A Ignition Module from Amazon and installed it.
The car seems to start easier, so I think that I fixed it, but the Check Engine Light is still on.
I want to Disconnect the battery in order to reset the ODB1 codes, but I don't know the code to the stock radio.
Is there a way to learn the code on this old bird?
The stock radio is working now, but I'm afraid that it will die if I disconnect the Batttery.
Old Jun 5, 2014 | 09:42 PM
holmesnmanny's Avatar
Default Re: Stock Radio Code, Can I get it while the radio is still connected?
Supposedly there's a tool that you plug into the cigarette lighter that keeps battery power to the vehicle even with the battery disconnected.
However, you can take your car down to the dealer and upon verifying ownership they will pull up the code for you.
I usually clear the code but some codes apparently will erase from the memory after some time. I'm not an expert on which ones though.
Old Jun 5, 2014 | 10:54 PM
MAD_MIKE's Avatar
MM Gruppe B
Does the lighter stay HOT when OFF?
On CDs the lighter is off when the key is not in II(ON) position.
jetlife if your mother was the original purchaser, have her call Honda of America and she will get the code for free. But you may need to pull the radio to get the serial number.
Old Jun 6, 2014 | 12:13 AM
they should be able to grab it via vin assuming its oem to that car
Old Jun 7, 2014 | 05:19 PM
jetlife's Avatar
Thanks, I have searched all of the paperwork, and I can't find the code anywhere.
I am sure that the battery has been replaced many times in this car.
I'll ask DM tomorrow if she knows the code. Perhaps this model doesn't have a code??
Is disconnecting the battery the only way to reset the Check Engine codes?
Old Jun 8, 2014 | 11:28 PM
brakedrum's Avatar
There is a 7.5 amp back-up fuse in the fusebox that is under the hood. Going from memory, it sits in the upper right corner of the box and is clearly marked 7.5. Carefully pull that fuse completely out for a seconds. That will clear the ECU code(s) without clearing the anti-theft radio code.
Old Jun 9, 2014 | 02:26 AM
thats also the radio back up fuse
Old Jun 11, 2014 | 10:22 PM
brakedrum's Avatar
I thought removing that fuse clears the codes in the ECU and maybe the clock. Didn't know it also clears the radio anti-theft code. Thanks.
Old Jun 11, 2014 | 11:22 PM
Hey, no problem. That's what this place is for. I love learning new things too.
bal
Apr 3, 2016 07:12 PM
junollie
Apr 24, 2012 10:38 AM
xcb7x
Jul 31, 2011 05:40 PM
Mattdaddy
Oct 12, 2004 06:56 PM
SHystrdyGSRtdy
Apr 12, 2003 03:11 PM
