Question about clutchmasters flywheel
Old Oct 30, 2002 | 04:31 PM
vtec69's Avatar
Default Question about clutchmasters flywheel
I was just installing my flywheel on my b18a and i noticed that the bolts that were included were too small for the flywheel to block holes.
The bolts that were included will only fit these holes
HAs this ever happened to anyone before?
Also are those bolts suppose to go in there?
I thought that those bolts were meant to go into here but they way to small for the hole.
Thanks
-Brian
Old Oct 30, 2002 | 04:36 PM
ragejed's Avatar
Default Re: Question about clutchmasters flywheel (vtec69)
Hmm, Arent you spose to reuse of buy new ones from acura, the bolts that hold the flywheel to the crank? The ones in your hand hold the clutch plate to the flywheel..right?
Old Oct 30, 2002 | 04:37 PM
vtec69's Avatar
Default Re: Question about clutchmasters flywheel (ragejed)
are you sure
Old Oct 31, 2002 | 02:27 AM
ragejed's Avatar
http://www.acuraautomotiveparts.net/...RQUE+CONVERTER
Number 8 is the bolt you use. Same as the one that held on your old flywheel to the crank.
Old Oct 31, 2002 | 05:16 AM
tilt's Avatar
mine cm flywheel didnt come with the bolt you show in the pic.... makes me wonder what it's for now.
Old Oct 31, 2002 | 05:36 AM
Ricky Rojales's Avatar
Looks like you got some free bolts to put in the bin. You reuse your original flywheel bolts to reattach the flywheel.
Old Oct 31, 2002 | 05:39 AM
vtec69's Avatar
Default Re: Question about clutchmasters flywheel (P)
i dont have them
Old Oct 31, 2002 | 06:12 AM
Sorry, but I don't remember the pitch, thread or grade for those bolts. Get them from the dealer if you must.
[Modified by P, 10:13 AM 10/31/2002]
Old Oct 31, 2002 | 07:09 AM
ragejed's Avatar
Like i stated before, acuraautomotiveparts.net either order them, or from your dealer. dont go cheap and get home depot
Old Oct 31, 2002 | 07:18 AM
IN VTEC's Avatar
i dont have them
der?
I find that really unusual. Didn't you just remove your old flywheel prior to installing this one? Or, is this an engine rebuild?
BTW, make sure you order the correct flywheel bolts....the manual tranny ones. The ones for the automatic trannies are shorter.
[Modified by IN VTEC, 10:18 AM 10/31/2002]
Old Oct 31, 2002 | 07:36 AM
vtec69's Avatar
Default Re: Question about clutchmasters flywheel (IN VTEC)
yeah im rebuilding the block
i dont have them
der?
hotrodlincoln
Sep 26, 2006 04:10 PM
kpop
May 21, 2006 04:54 PM
preluda92
Aug 30, 2003 02:29 AM
vtec69
Apr 12, 2003 10:23 AM
vtec69
Oct 30, 2002 04:59 PM
