Help with custom engine mount
Old Jun 3, 2014 | 06:08 PM
preludeNApower's Avatar
Default Help with custom engine mount
I am fabricating an engine mount (cause mine was ripped out from too much vtec). Here is my first mock up. What do you think of the design? Please tell me how I can improve on this. And any suggestions to get it at the correct height so the engine sits properly?
Old Jun 4, 2014 | 05:34 AM
GSRinmyCRX's Avatar
Default Re: Help with custom engine mount
you would probably be better off going ot a junk yard and cutting off the oem mount that you need. weld every spot where it contacts the frame of the car. if you are hell bent on making your own mount you need to add some support vertically and attached to the frame rail. if you dont all the stress will be on your welds and nothing else. look at the oem design and try and replicate it.
Levi
Old Jun 4, 2014 | 10:09 AM
2fast4u831's Avatar
I'm really 2slow
Weld another piece on each side of the frame rail to make an L shape.
Old Jun 4, 2014 | 02:31 PM
Are you guys talking about a vertical L where the squiggly sharpie marks are? I was thinking that and gussets
Old Jun 4, 2014 | 07:06 PM
2fast4u831's Avatar
I'm really 2slow
yes! right there. Without any support there the bracket will want to tilt towards the transmission.
Old Jun 4, 2014 | 07:38 PM
Roger. Plan on adding that.
Progress, tacked up.
Going to mark it up, take it off, drill holes, then weld it all up and add supports
HC4
Honda CR-V & Element
Jul 1, 2019 11:34 AM
roland021
Mar 22, 2010 04:51 AM
fluke702
May 14, 2009 05:23 PM
balistic CRX
Dec 27, 2001 04:37 AM
