My fabricated engine mount. Critique it
Old Jun 3, 2014 | 06:04 PM
preludeNApower's Avatar
Default My fabricated engine mount. Critique it
Soooo, I am fabricating an engine mount (cause mine was ripped out from too much vtec). Here is my first mock up. What do you think of the design? Please tell me how I can improve on this. And any suggestions to get it at the correct height so the engine sits properly?
#all done
Old Jun 3, 2014 | 10:32 PM
Sparksman's Avatar
Default Re: My fabricated engine mount. Critique it
Wont let me view it....
Old Jun 4, 2014 | 05:10 AM
Don Jefe's Avatar
Me neither, I'd like to check it out though.
Maybe upload to imgur and post up the link (or embed)?
Old Jun 4, 2014 | 02:26 PM
Old Jun 4, 2014 | 02:27 PM
Old Jun 4, 2014 | 06:51 PM
Sparksman's Avatar
I dont know much about fab work, but it looks good!
Old Jun 4, 2014 | 06:59 PM
Tacked in place, going to take it off, weld the rear T, drill the hole, then weld it in. I am also going to add gussets on the front and back and put a plate on top.
Old Jun 4, 2014 | 07:00 PM
Old Jun 6, 2014 | 05:36 AM
98vtec's Avatar
moderator emeritus
you need to give it bracing on the side of the frame. i cant tell from the picture but it looks like you have two flats of steel running straight across to the top of the frame. you need a contact point on the bottom, both sides of the mount.
Old Jun 9, 2014 | 04:49 AM
pentaq's Avatar
yep, you need support from the bottom. It will drop off/break the weld if you hit the hole on the road.
Old Jun 14, 2014 | 05:38 PM
preludeNApower
Welding / Fabrication
Jun 4, 2014 07:38 PM
dakota1820
Honda Civic (2001 - 2005)
Jul 5, 2013 09:02 PM
balistic CRX
Dec 27, 2001 04:37 AM
