Help my car died!! 1990 integra GS b18a1
I was diving and boom my integra shut off out of nowhere. I had a skrew driver and checked for spark and nothing. It's getting fuel my main relay is fine it's brand new. What should I check? Does anybody think it's the distributer?
Are you saying there is no power on the black/yellow lead going to the distributor assembly, [when ign. switch is on]?
If so, check fuse #24 in the under dash fuse box, check both test tips on the fuse with the fuse in the fuse box and ign. switch in both the run and start positions. 94
Are you saying there is no power on the black/yellow lead going to the distributor assembly, [when ign. switch is on]? If so, check fuse #24 in the under dash fuse box, check both test tips on the fuse with the fuse in the fuse box and ign. switch in both the run and start positions. 94
I got it running for a week but now it died again and there is very low charge to the coil when I crank on it, it's fine sitting there. How do I check the ignitors and the ecu?
jdmsiR20
14
Nov 6, 2003 11:13 PM
