JDM Y21 transmission with Quaife will 4.785 final drive fit?
Old Oct 30, 2002 | 04:05 PM
rolow's Avatar
Default JDM Y21 transmission with Quaife will 4.785 final drive fit?
I have a JDM Y21 transmission with a Quaife LSD and I want to know if the JDM ITR(4.785) Final drive will fit my transmission?
Mike
Old Nov 1, 2002 | 07:37 AM
rolow's Avatar
Default Re: JDM Y21 transmission with Quaife will 4.785 final drive fit? (rolow)
up
Old Nov 1, 2002 | 10:45 AM
Katman's Avatar
Mike
Ok here's the thing.
You can get a 4.7FD to fit in your Y21, problem is you need to use a GSR/Si Coupe/ITR/or CTR FD ring gear which is actually bigger in diameter. So that means, you'd lose out on reusing your queeef LSD. Y21 & S21 tranny's both have a smaller diameter sized FD ring gear. I know, Honda sucks like that with their unorthodox ways.
[Modified by Katman, 11:46 AM 11/1/2002]
Old Nov 1, 2002 | 03:30 PM
rolow's Avatar
Default Re: JDM Y21 transmission with Quaife will 4.785 final drive fit? (Katman)
That sucks
If I sell my tranny what should I get?
Old Nov 3, 2002 | 11:58 PM
Katman's Avatar
That sucks
well if you want a tranny that will accept a 4.7fd, you'll either want once of these hydro b-series trannys:
ITR/CTR
Si coupe (S4C)
94+ GSR
94+ LS
of course the Si coupe and ITR/CTR trannies have the same gearing. You're best off with an ITR/CTR trans out of all those choices though.
Old Nov 4, 2002 | 06:00 AM
rolow's Avatar
Besides the lsd what is the difference Between the 99-00 si and the ITR/CTR?
[Modified by rolow, 3:02 PM 11/4/2002]
Old Nov 4, 2002 | 07:02 AM
acura_typer's Avatar
Banned
I wasnt aware the S4C had the same size ring gear as a 94+ GSR. I always thought it was the bolt pattern that was different, which is why you couldnt use a ITR LSD in a Y21 with the Y21 ring gear. The 99-00 Si has the same diff part number as the Y21, which is different than the S80 (GSR)
Old Nov 4, 2002 | 07:21 AM
rolow's Avatar
Default Re: JDM Y21 transmission with Quaife will 4.785 final drive fit? (acura_typer)
I am more confused than ever
[Modified by rolow, 4:23 PM 11/4/2002]
Old Nov 4, 2002 | 07:57 AM
CHEETAH's Avatar
the s4c has the LS bolt pattern and offset as the LS .. it is not compatible with GSR and Type R ring gears.
Greg
Old Nov 4, 2002 | 08:02 AM
rolow's Avatar
Default Re: JDM Y21 transmission with Quaife will 4.785 final drive fit? (CHEETAH)
So the s4c is 99-00 Si?
Will the jdm 4.785 fit the 99-00 si?
Old Nov 4, 2002 | 09:05 AM
CHEETAH's Avatar
yes, with 94+ GSR and ITR/CTR differential.
Greg
Old Nov 4, 2002 | 01:04 PM
carchitect's Avatar
Y21 tranny what does that go to?
Quaife makes a final drive that fits the diff you are using. Why don't you give quaife a call?
Old Nov 4, 2002 | 01:07 PM
Banned
Default Re: JDM Y21 transmission with Quaife will 4.785 final drive fit? (carchitect)
Y21 is the Del Sol VTEC tranny.
The JDM FD will fit in a Y21/S4C if you install the GSR/ITR diff (from who ever you like).
Also, use ITR bearings if you use the ITR/GSR diff.
Old Nov 8, 2002 | 05:46 AM
rolow's Avatar
One more time to the top!
So I can install the 4.785 final drive in my Y21 with an ITR diff and bearings?
Is that all I need?
Old Nov 8, 2002 | 06:04 AM
CHEETAH's Avatar
Is that all I need?
depending on differential bearing clearance, you may need c-clip shims from the dealer. On 95% of the trannies that I do I am able to flip the clip to the lower casing and it gets within tolerance. Maybe you'll get lucky, but be sure pop out the seals and check with feeler guage.
Other than that, you just need the JDM final drive kit which includes 1st gear main, countershaft, needle bearings and holder, etc.
greg
Lil Krayzee
Sep 2, 2007 08:57 AM
DJ Gurgla GSR
Jul 3, 2006 12:23 PM
K20A3T
Sep 15, 2004 11:40 PM
Myleatherseats
May 17, 2003 03:26 PM
shamoo
Mar 15, 2002 06:33 PM
