99-00 Civic si cluster tach repair?
Old May 31, 2014 | 08:15 AM
ektamalekid's Avatar
Default 99-00 Civic si cluster tach repair?
I have a 99-00 Si cluster in a 96 civic dx hatch and the tach decides to work every once in a while...The continuity has been checked on the tach wire coming from the dizzy to the cluster and it checks out fine, we tried a different cluster and the tach worked fine...so we know it's the tach...Does anyone know if the a malfunctioning tach can be repaired? i've had no luck tracking down just a SI tach on ebay and they're like $500 from Honda lol..orrr anyone on here maybe have a broken cluster with a working tach they'd want to part with? Either way if you have any info on whether or not the tach can be repaired please let me know.
-Thank You
Old May 31, 2014 | 08:36 AM
94EG8's Avatar
Seagull Management
Default Re: 99-00 Civic si cluster tach repair?
Often if you just heat up all the solder points with a soldering iron it will fix them.
Old May 31, 2014 | 09:02 AM
KiNGDEE206's Avatar
i have a whole 96-00 rpm cluster working for sale if u want, 30 bucks for it itself and prolly 20-25 for shipping. Downside is broken temp gauge, but u are only just using the rpm gauge anyways so u can remove my rpm gauge and swap it with ur SI one. but keep ur SI face plate
and if u already have a rpm cluster (donor) u can just swap the RPM gauge out with ur SI one. but again, keep your SI face plate
Old May 31, 2014 | 09:20 AM
I think i'll try this, thanks for the input
new_climber
May 13, 2013 12:25 PM
HFXCIVIC
23
May 4, 2012 12:54 AM
DCRB
Oct 10, 2008 08:25 PM
outkast_15
Oct 31, 2005 09:58 PM
EpDarks
Nov 17, 2002 09:34 PM
