coolant temp sensor help
Old May 30, 2014 | 08:29 PM
dom_ef1992's Avatar
Default coolant temp sensor help
So i replaced my rear main seal and my coolant temp sensor stopped working. Was working fine before we replaced the seal. i have replaced the actual sensor, ive replaced the coolant temp pigtail, i checked the connector for the gauge and the wires dont look to be pinched/damaged. And its still not working... any idea what it might be is there a fuse or a relay i might have blown, and if so which one is it....
any write ups will be helpful
Old May 31, 2014 | 03:43 AM
~sp33~'s Avatar
EFB055
Default Re: coolant temp sensor help
Did you check the coolant temperature switch or the gauge sender?
One acts as a switch to turn the radiator fan on, the other sends a signal to the temperature gauge.
Depending on your car/engine the gauge sender is the single wire that bolts under your dizzy. Should be part of your 02 sensor/reverse light portion of your engine harness.
Old May 31, 2014 | 05:56 PM
Austin Gelinas's Avatar
I have a question regarding my coolant temp sensor. my 91 crx has a sensor with two wires but the wiring harness was swapped with one from a newer civic. those sensors only have one wire. how do i solve this problem?
Old May 31, 2014 | 06:22 PM
I have a 91 crx with a 92-95 civic motor. I believe the sensor is usually on the head of those motors but it is not the case here. the sensor is separate from the engine and is the two wire design. i only have one wire going to my sensor. it does not work. i did not do the swap in this car, it was like this when i got it. any advice on how to get the sensor working?
ARL97
Jun 3, 2017 10:07 AM
diamondwhite50
Jul 5, 2007 04:43 AM
vtecaccord 1
Dec 7, 2004 05:59 AM
SPORT INJECTION
Oct 31, 2004 10:36 PM
JoshM
Jun 2, 2002 06:11 PM
