b18A1 what is this on back of block?
Old May 30, 2014 | 04:21 PM
kenneth4g4d's Avatar
Default b18A1 what is this on back of block?
As in title says, what is this that is plugged in on the back of a b18A1 block to the left of the oil filter? Also to unplug it does it just slide out?
Old May 30, 2014 | 04:25 PM
B_Swapped93's Avatar
Default Re: b18A1 what is this on back of block?
oil pressure sensor(not related to VTEC)
Old May 30, 2014 | 04:30 PM
kfish's Avatar
Yes it just slides off. It's just a bullet connector.
Old May 30, 2014 | 05:25 PM
ok thanks i tryed to pry it off but seems a bit tight lol thanks again
Old May 31, 2014 | 04:25 AM
TheRealTegger's Avatar
I't s"tight" because the rubber is ancient and is rock-hard.
I had to cut mine off entirely by putting a slit in the end closest to the block. That enabled the rubber to expand and unhook from the sensor.
blackeg
Aug 17, 2007 03:48 AM
em1 Ziggy
May 12, 2006 11:08 PM
mo0cow
Oct 26, 2005 04:36 AM
