1994 accord transmission problem.
Old May 30, 2014 | 07:05 AM
onunezp's Avatar
Default 1994 accord transmission problem.
Hello guys, im new here but ive been looking around this forum for a while now and i see you all know everything about or beloved accords, my transmission is going bad, when i start my car it works fine, it shifts, but after a few meters its like the transmission goes neutral and my car stops, i have to shut it down, cool off and then start it and leave, i ve been reading that it might be the filter in the transmission, what is your opinion? and if its the filter, can i change it without putting down the whole tranny? its very expensive in my country,
thanks in advance.
Old May 30, 2014 | 12:18 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 1994 accord transmission problem.
You can try draining the old fluid out, put in some transmission cleaner, not stop leak, and drain again.
There is no transmission pan. The only way to get to it would be to remove the transmission and open the case.
Old Jun 25, 2014 | 12:00 PM
onunezp's Avatar
Thanks a lot man, you are a genius, worked fine. thanks!!! :D
Old Jun 25, 2014 | 01:06 PM
MAD_MIKE's Avatar
MM Gruppe B
Excellent.
Laceyfer
Jul 20, 2009 02:25 PM
norton54
Jan 20, 2007 03:46 AM
pinoy369
Nov 4, 2006 09:25 AM
wopspice
Feb 17, 2003 06:16 AM
