Changing Wastegate and Blow Off Valve on a Revhard Kit
Old Oct 30, 2002 | 02:52 PM
Fatty_1775's Avatar
Default Changing Wastegate and Blow Off Valve on a Revhard Kit
Anyone know the size of wastegate that is on a revhard turbo kit? I know it comes with a deltagate and I want to change it to a tial wastegate. Also, with what kind of blow off valve can I swap in the vortech one with and will it just bolt on? Thanks.
Old Oct 30, 2002 | 03:02 PM
inspyral's Avatar
Default Re: Changing Wastegate and Blow Off Valve on a Revhard Kit (import_racer)
The w/g should be 35mm.
Old Oct 30, 2002 | 03:03 PM
I Like Boost's Avatar
the deltagate can be directly swapped out for a 35mm tial. any bov can be put on to the charge pipe you just have to get someone to weld on the flange for that certain bov.
Old Oct 30, 2002 | 03:08 PM
ArizonaTurbo's Avatar
You can swap the Deltagate out to a Tial 35mm and you can mount a Greddy Type "S", Greddy Type "R" or HKS Standard BOV.
Old Oct 30, 2002 | 03:13 PM
Fatty_1775's Avatar
Default Re: Changing Wastegate and Blow Off Valve on a Revhard Kit (TurbochargedSER)
How about an HKS super sequential? Thanks for your help guys!!!
Old Oct 30, 2002 | 03:47 PM
phase12gsr's Avatar
for the HKS Super Sequential you'll need a new flange or some kind of custom made adaptor flange
Old Oct 30, 2002 | 05:41 PM
turbo craig's Avatar
Default Re: Changing Wastegate and Blow Off Valve on a Revhard Kit (phase12gsr)
i have the vortech bov that came wid the kit are there any bovs that share that flange?
Old Apr 26, 2003 | 06:05 PM
kHoA DoGG's Avatar
Default Re: Changing Wastegate and Blow Off Valve on a Revhard Kit (turbo craig)
hey... noone answered the share flange question... i'm wondering the same thing tooo....
Old Apr 26, 2003 | 06:12 PM
tony1's Avatar
Default Re: Changing Wastegate and Blow Off Valve on a Revhard Kit (sNoOziN' EF8)
you guys need to pay attention Look at turboser's post...
Old Apr 26, 2003 | 11:04 PM
kHoA DoGG's Avatar
Default Re: Changing Wastegate and Blow Off Valve on a Revhard Kit (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">you guys need to pay attention Look at turboser's post...</TD></TR></TABLE>
and where is that post?
Old Apr 26, 2003 | 11:52 PM
intekragsr's Avatar
4th post down
"You can swap the Deltagate out to a Tial 35mm and you can mount a Greddy Type "S", Greddy Type "R" or HKS Standard BOV."
how u guys miss it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sNoOziN' EF8 &raquo;</TD></TR><TR><TD CLASS="quote">
and where is that post?</TD></TR></TABLE>
Old Apr 27, 2003 | 12:11 AM
kHoA DoGG's Avatar
Default Re: Changing Wastegate and Blow Off Valve on a Revhard Kit (intekragsr)
hahah, not that question but the question about sharing the same flange w/ the vortech BOV. sort of like plug and play. another case of miscommunication.
Old Apr 27, 2003 | 08:24 AM
tony1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sNoOziN' EF8 &raquo;</TD></TR><TR><TD CLASS="quote">hahah, not that question but the question about sharing the same flange w/ the vortech BOV. sort of like plug and play. another case of miscommunication.</TD></TR></TABLE>
"Greddy Type "S", Greddy Type "R" or HKS Standard BOV."
Those are bovs...
Old Apr 27, 2003 | 09:38 AM
kHoA DoGG's Avatar
thanks! so those should just be plug and play.
Old Apr 27, 2003 | 11:55 AM
Adriano's Avatar
I believe that the new Rev Hard kit comes with a turbo smart w/g. My brother just go his kit 2 weeks ago and it came with a turbo smart w/g.
Old Apr 28, 2003 | 07:22 AM
Default Re: Changing Wastegate and Blow Off Valve on a Revhard Kit (brryder)
now that i have the vortech bov installed i dont want another bov it sounds perfect
Old May 3, 2003 | 02:27 PM
Kutsuju_SLeePER's Avatar
I ordered the Rev Hard Stage 2 c from John at Afterhourz and
I swapped out the BOV and the WG for a new TIAL and HKS SBOV
the BOV will fit fine if u wanna swap it out no problem along with the WG.
Old May 9, 2003 | 07:32 PM
Muckman's Avatar
Moderator in Chief
Default Re: Changing Wastegate and Blow Off Valve on a Revhard Kit (Kutsuju_SLeePER)
Did After Hourz allow you to swap parts within the kit?
How hard is it swap out the deltagate to a Tial external wastegate? And whats this new Turbo Smart Wastegate? How does that compare to the Tial?
Old May 21, 2003 | 05:51 PM
Kyoji's Avatar
Default Re: Changing Wastegate and Blow Off Valve on a Revhard Kit (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Did After Hourz allow you to swap parts within the kit?
How hard is it swap out the deltagate to a Tial external wastegate? And whats this new Turbo Smart Wastegate? How does that compare to the Tial?</TD></TR></TABLE>
I would also like to know... I might be going the Rev Hard route.
Speed Infliction
Dec 12, 2006 11:15 AM
LS stretch
Nov 17, 2006 02:58 PM
EikoU
Nov 1, 2005 05:50 PM
1.8T_EG
Apr 9, 2003 08:18 AM
