H22A/H23 FRM, which pistons & rings, cams
Old May 29, 2014 | 04:56 AM
gmcuajo1's Avatar
Default H22A/H23 FRM, which pistons & rings, cams
I have an h22a with h23 crank & rods. It have p13 vtec head. In other words, it h23 vtec. I wasn't sure what to build. Thinked about h2b, turbo with and without resleeve... Because I don't want to throw all that money I will go N/A with a mild refresh of the internals.
My questions:
As it is FRM I just can't throw forged pistons without resleeve. Which pistons can I use? Can I use the type-s pistons from eBay to get higher compression? Will them work with h23 stroke & rod length?
http://m.ebay.com/itm/181401984292?nav=WATCHING_ACTIVE
I read on other thread that type-s cam shaft will have clearance issues with the valve guides? Is that right, any form to solve this? Other better/good OEM/aftermarket cam to go with?
Any other advise is good to hear!
Old May 29, 2014 | 09:23 AM
HiProfile's Avatar
Default Re: H22A/H23 FRM, which pistons & rings, cams
They'll stick out 0.020" on an undecked block. The H22 head has ~0.045" of a recess til you get to the quench pads, but it's actually ~86.5mm. If you open the combustion chambers 0.3mm all the way around, there shouldn't be any HEAD clearance problems.
You'll still want to check valve clearance. H22 pistons will stick out the same, so if you have a set you can use them to clay it for P2V clearance. Otherwise you'll need to get at least a 0.046" headgasket, dropping CR to 11.5:1 from 12.1:1.
A 95mm H22 is quite a bit of torque & power for a H2B Civic/Integra/CRX, especially with cams & compression.
Old May 29, 2014 | 10:35 AM
gmcuajo1's Avatar
The motor already have the setup done. I will have to double check what gasket it have. Have to check for valve clearance too.
My major concern is the fact of the frm cylinders. Not sure which pistons I can use. Also the clearance issues with type s or aftermarket cams.
Old Jun 1, 2014 | 04:11 PM
gmcuajo1's Avatar
Anyone with an H23 or H22 with type s or any high compression piston?
Old Jun 15, 2014 | 10:56 AM
gmcuajo1's Avatar
Have concerns about p2v clearance.
Decide t o stay with my setup, h22A block & pistons (p13) with f22 95mm stroke & rods. Basiclly h23 with h22 pistons. Pistons top (dome obviouly is out) "looks" almost flush with the block.
Have stock cams but I would want to know piston to valve clearance to be sure how far I can go with cam advance/retard, and obviously if can put those high compression piston and other cams.
Also the head is stock but I will send to "resurface". Just enough to have a flat surface.
Old Jun 15, 2014 | 11:04 AM
gmcuajo1's Avatar
Some pics
eg2ek2dc
Feb 15, 2009 05:59 AM
roycivic92
Jan 28, 2006 09:21 PM
satan_srv
Mar 18, 2003 05:30 PM
AndyD
Nov 24, 2002 01:23 PM
jarel
May 9, 2002 10:20 AM
