just did a clutch change and now I have a bolt problem
Old May 28, 2014 | 03:09 PM
James Long's Avatar
Default just did a clutch change and now I have a bolt problem
long story short i started this job and had to let it sit for 2 weeks, now i have the transmission on but I have 2 long bolts. 1 i assume is for the starter as it is the proper length but i have no clue what to do with the other bolt.. I have all the bolts in but the starter and bottom block bolt that is next to the oil filter...
I took all of the bolts out one at a time and checked to see if the long bolt would fit but it does not... is there another long bolt i am missing (yes the engine to frame mount bolt is installed).
any advice appreciated thanks!
Old May 28, 2014 | 03:25 PM
bajasti's Avatar
Default Re: just did a clutch change and now I have a bolt problem
Rear mount bracket possibly? Pics would help..
Old May 28, 2014 | 03:59 PM
James Long's Avatar
nope that isn't it. there are 8 bolts total. 6 are installed. one bolt is for the starter and the other one well... idk. I took out every single bell housing bolt and tried sticking the long one in and no luck.
All i can think of is I lost a bolt and the other long bolt belongs somewhere else that i have completely forgotten about.
the bolt is 4" from shank to tip.
Old May 28, 2014 | 06:20 PM
holmesnmanny's Avatar
probably for the tranny mount
Old May 28, 2014 | 10:31 PM
MAD_MIKE's Avatar
MM Gruppe B
Would help if you stated what year and engine you have.
Or you could go to Majestics online site and look up the bolt lengths yourself.
Old May 29, 2014 | 02:14 PM
James Long's Avatar
i figured it out.... It was the dust cover... Doh!
Nbboy7
Jun 24, 2008 02:36 PM
spidermancivic
Aug 11, 2007 08:17 AM
BoostinEJ1
41
Apr 16, 2006 01:18 PM
BJOnewiper
Dec 10, 2005 01:15 PM
flip b18b
Jun 28, 2004 10:31 PM
