96 integra wont start. Helpp!!!
Okay so ive read a good amount of threads and still nothing has helped. So i have a 96 integra 5 speed b18 no mods. At first i would hear a click from the starter so i said y not took it to auto zone since was under warranty i got a new one same thing nothing changed. Then i tried swapping battery for one that i know is good and got the same results. Swapped outain relay for one in working condition and nothing. I hear fuel pump prime and right when i turn key to crank motor it just makes a single click from starter. Im stuck idk what else to do to make it start. Any ideas what the problem could be??? There is no cel light. Light come on and goes off after a few seconds like it should. Tested the battery volts while trying to crank and get 11v while crank and 12 just sitting. Ughhh also replaced distributor and wires but one that i know is good and still nothing. Helppp!!!!!
My 90 teg does the same thing. I think there is a bad spot in the fly wheel or some how the starter pinion gear is getting stuck on the flywheel. pull the starter out and inspect your flywheel.
