fs/testing waters:b18c motor
wanted to rebuild my buddies motor but right now its going to cost me more than i have at this time
$1500 + shipping Obo
Engine:
JDM b18c gsr motor
Ctr pistons
Alaniz Full race port & polish head / fully decked
Crower springs and retainers
Skunk2 tuner stage 2 cams
skunk2 cam gears
ls intake studs
Skunk2/Blox intake manifold
hondata thermal intake gasket- (need replace,became brital)
JDM integra type r throttle body
RC 440cc injectors
unorthodox pulley
arp head studs
toda timing belt
-new eagle crankshaft
-head cleaned,checked, new valve seals should be back from machine shop next week
Engine:
JDM b18c gsr motor
Ctr pistons
skunk2 cam gears
ls intake studs
RC 440cc injectors
unorthodox pulley
arp head studs
toda timing belt
Looking at a set from a member on here. If I don't hear back from them tonight I'll let you know.
Wish I could find a crank too.
What parts are you looking/wanting?
Main caps,arp head studs, crank,oil pan....
Have a set of gsr piston that should be here tomorrow
-or ctr pistons would want more for
-pretty much a complete bottom end
Bump for any offers
May split if offer is right
Was thinking 800 pick up minus pulley, distributor,and injectors
-May want to keep the cam gears
-hope to have the crank back this week
Was looking to sell it because I don't have the money to rebuild it right now
If there are no offers then I'll just keep it and rebuild it over time
I'm a honda tech but I think I got about $800 that will be needed because I would want to replace all the seals and other parts (water pump...) while I have it out
- last motor I swapped I rushed and ended up going back and replacing parts
The block would come with everything in the bottom end crank,oil pan, pistons, rods, oil pump,head studs,water pump ...
- did not get a chance to call about the crank. It should have been done today, while I was told 5-6 days.
-calling tomorrow and Aldo seeing about doing valve seals and have the head cleaned
Not sure, have not really thought about a price yet since I'm still waiting for the crank to get back. If you want to shot me an offer
