Weird oil drain plug broke inside the oil pan... please help!
Old May 27, 2014 | 02:25 PM
whytetygerwolf's Avatar
Icon3 Weird oil drain plug broke inside the oil pan... please help!
Hi everyone, slight emergency, well hopefully it ends up not being one but i need some advice.
My 99 civic ex has this weird oil drain plug i've never seen on a car before, and it broke with one end which i assume has the threads is still inside the oil pan.
I'm going to try to get it out with a magnet hopefully but if that doesn't work would it be safe to say I need to pull the oil pan to get it out? I really don't get why this is even an oil plug looks like a terrible idea to use over the traditional kind.
Old May 27, 2014 | 02:28 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Weird oil drain plug broke inside the oil pan... please help!
Answered your own question.
Old May 27, 2014 | 02:31 PM
burnoutboy's Avatar
The Credible Hulk
Looks like one of those shitty quick oil change plugs. GLWT
Old May 27, 2014 | 02:35 PM
bajasti's Avatar
I believe thats one of those "I dont want to replace my oil pan plugs" seems to me like the threads on the drain hole has probably been stripped or cross threaded and this was their fix. check to see if the threads are there and in good condition. Try to thread in a OE plug and see if it holds oil. if not, I would just replace the oil pan and make sure you get ALL the metal shavings out if any present. Some people will use a oversized plug but honestly I never had any luck with them just more headaches... good luck man
Old May 27, 2014 | 02:39 PM
the threads look OK, but there still is a little piece of metal in there i can get part of the way out with a magnet, but not all the way out. Really didn't feel like pulling the oil pan this weekend....
Old May 27, 2014 | 02:42 PM
bajasti's Avatar
the question is.....what kind of metal is it? if its aluminum, your not going to get it with a magnet and you might have bigger issues. if it sticks to the magnet the i dont see how you cant fish it out. is the piece that big? try flushing it out by pouring in oil through the top...
Old May 27, 2014 | 02:43 PM
bajasti's Avatar
also shine a flashlight in the oil and see if you see any more metals....
Old May 27, 2014 | 02:44 PM
the metal is steel. I don't know why it won't come out either it feels like it must be bigger on the inside, which doesn't make sense how it got in there in the first place
Old May 27, 2014 | 02:47 PM
The Grumpiest
Maybe they removed the pan to install it.
Old May 27, 2014 | 02:48 PM
bajasti's Avatar
looks like your gonna have to pull the oil pan this weekend. it could be the nut/washer that goes on the other end of that plug. I have seen similar fixes in my shop. I believe you actually have to pull the oil pan to install one of those properly. someone probably didnt want or could afford a new oil pan at that time :-(
Old May 27, 2014 | 02:50 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Shouldn't be aluminum. That's a pan saver plug. When the drain plug threads are stripped badly enough those are used to seal up the pan since a plug won't work or they don't have a tap and die set to tap it to an over size.
The part inside the pan is like the drywall hangars for the ceiling, it folds in half and springs back out to make a T- shape. If you can get it near the hole it should fit out through it.
If you have a steel pan the magnet might not be very effective unlike an aluminum pan. If you have those small flexible claw grabbers and a good flashlight you might be able to grab it that way.
If not then dropping the pan to get it out is your only option. If it can fit through the oil pickup tube mouth the screen will stop it and it probably wouldn't affect much, if it can't fit through the pickup tube mouth, then it could really restrict oil flow by blocking the majority of the pickup tube's opening.
I'd personally get it out. I also have a really nice long flex grabber that is both magnetic and a 4 claw grabber that I can insert into my drain pan plug hole.
The piece in your pan looks like the piece on this bolt at home depot:
http://www.homedepot.com/p/Unbranded...3?N=5yc1vZc2eq
The Grumpiest
Found it.
Old May 27, 2014 | 02:53 PM
bajasti's Avatar
I just wouldnt feel good knowing one of those is in my oil pan. smh
Old May 27, 2014 | 02:55 PM
^^^ thats the thing. The end part is steel, i can get it almost out with a magnet and i can grab the very end of it but thats all. I guess i get to keep trying to wiggle it through but i dont think its coming >:\
Old May 27, 2014 | 03:00 PM
bajasti's Avatar
just pull the pan man. it'll make you feel better when you know theres nothing in there thats not suppose to be. Did you try threading in a OE plug? you still may need to tap for oversized or just get a new oil pan. you'll probably save time too.
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Correction, it pivots on the swivel and rides along the bolt, the old ones in the 90's folded in half like the home depot drywall empty space anchors. Guess they broke to often so the design was changed to the rigid type on a swivel.
If you get it long ways it should slide right through the drain hole unless it's horribly mangled.
Old May 27, 2014 | 03:14 PM
The Grumpiest
It's a glorified toggle bolt.
Old May 27, 2014 | 05:06 PM
tony_2018's Avatar
Fish Twig
Take the oil pan out, the threads are probably fucked thats why they ghetto that on there. Be prepared to go junkyard hopping for an oil pan.
Old May 27, 2014 | 05:56 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
If he can get the toggle part of the bolt out, he can tap it for an over sized drain plug. A little easier process than a pan swap and gasket etc.
sparkyk20eg
K Series
Aug 22, 2018 08:01 PM
z4nd
Honda Civic (2001 - 2005)
27
Oct 2, 2010 09:39 PM
shadohconspiracy
15
Oct 13, 2007 02:08 PM
conors
Sep 10, 2003 03:43 PM
FredoSP
May 14, 2002 05:14 AM
