Honda Accord Engine Swap
Old May 27, 2014 | 12:36 PM
nd1fan's Avatar
Default Honda Accord Engine Swap
I had a guy swap out my old engine, blown head gasket, for a used engine. He put the engine in and now it cranks but won't start. Any suggestions where to start from here?
Old May 27, 2014 | 01:30 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Honda Accord Engine Swap
I have not been able to channel Carnac the Magnificent lately, so your gonna have to throw me a bone.
Old May 27, 2014 | 03:07 PM
nd1fan's Avatar
When the key is turned the engine cranks but will not fire.
Old May 27, 2014 | 03:24 PM
GhostAccord's Avatar
So what is it missing, fuel or spark?
Just a shot in the dark here but you could try checking the engine grounds.
Old May 27, 2014 | 03:33 PM
djkurious's Avatar
Make, model, engine?
Old May 28, 2014 | 08:52 AM
tim73's Avatar
Check all wiring first. Make sure none of the plugs have been left off, or swapped. After this, check for spark. If good, shoot a shot of starting fluid in, and try to start. Although, more info would be good.
Old May 28, 2014 | 03:03 PM
Grandhustleman86's Avatar
Firstly - ^bwahahahahahahaha....
I dont see a blown head gasket warranting swapping out the motor. To easy to repair and so much info online on how to change a head gasket properly on many different cars.
Did you pay this "Mechanic"? Have you asked him to assist in finding a solution to the "No start" issue? Other than that youve been WAY to vague. Need to supply some specifics like Year-Model_Engine Code...3 vital questions that need answers before anyone on here can truly point you in the right direction.
Old Jun 2, 2014 | 10:24 AM
nd1fan's Avatar
Thanks, it is a 1999 Honda Accord LX with a vetch motor four cylinder.
Old Jun 4, 2014 | 02:36 PM
Lost Again's Avatar
And the answer to this is?
Did you check the main ground (G101)?
Toimimou
Honda CR-V & Element
Nov 21, 2018 09:23 PM
nsiders09
11
Mar 3, 2016 03:01 PM
Grak Fu
Aug 12, 2013 07:39 PM
Hondamatic-s
Classic Hondas
Feb 24, 2010 05:50 PM
trustbuddy
Jan 14, 2006 08:27 PM
