92 prelude f22 needs some help!
Old May 27, 2014 | 12:32 PM
snoopaloop986's Avatar
Default 92 prelude f22 needs some help!
My 92 lude is mis firing I think only at low rpm if I keep them at a higher rate than normal driving it won't miss but say I'm driving in fifth gear and I slow down enough to drop the rpm under say 2000 and try to speed up it will miss quite a bit eventually smoothing out to normal but it is bothering me a lot I checked the cap and rotor and it had some build up but it cleaned right off and looks brand new now the plugs and wires are like a month old so I wouldn't think they would be bad I did notice that most of the build up on the rotor was mostly from the center to the side please if anyone could shed some honda knowledge let me know
Old May 27, 2014 | 05:04 PM
AudioFunk's Avatar
Default Re: 92 prelude f22 needs some help!
Any CEL?
Old May 28, 2014 | 02:18 AM
Originally Posted by AudioFunk
Any CEL?
I don't know exactly what that is lol cel?
Old May 28, 2014 | 02:19 AM
Any CEL?
Oh never mind the last comment lol I'm a dumb *** lol no the check engine light never comes on
Old May 28, 2014 | 01:38 PM
Sparksman's Avatar
If its only at low rpm's check your IACV, the TPS, and your ignition timing.
Old May 29, 2014 | 12:06 PM
Can u adjust the ignition timing without having to get all into the timing belt?
Old May 29, 2014 | 02:10 PM
Sparksman's Avatar
ya, first you have to jump the CEL plug with a paper clip or spare wire.
Then connect timing gun to battery and plug wire on Cyl #1 "closest to belts"
Loosen the bolt on the distributor, dont remove!
Remove plug between block and engine to see timing marks on the flywheel
Use the light to find the lines on the flywheel and rotate the dizzy to line it up with the marks on the block.
Tighten dizzy bolts and unjump the CEl plug. Done.
Old Jun 9, 2014 | 11:54 AM
I have noticed it's after its gotten warmed up when it starts missing at low rpm's
92hatch_12
15
Dec 2, 2011 11:46 PM
anewman89
Oct 12, 2010 08:31 AM
Frank Allen
Jan 12, 2010 06:52 AM
5g
Oct 7, 2006 04:06 PM
bobbysunshine
Feb 2, 2006 03:54 AM
