Help Me!!! Dc5 wont go into gear
Old May 26, 2014 | 05:04 PM
meeka661's Avatar
Icon3 Help Me!!! Dc5 wont go into gear
Ok so yesterday i drove to the store and everything was fine. get back into the car and try to drive off and it wont go into gear. i pop the hood and notice a bolt is missing from tranny mount. i put a bolt in when i got it home and still nothing. It goes into gear if the car is off but not on. there is still pressure in the clutch and feels normal when it is off. when its on the clutch feels a little wierd. my friend bled it and still nothing. its an 05 Type S btw. somebody please help me!
Old May 26, 2014 | 08:31 PM
NHBP-TypeS's Avatar
Default Re: Help Me!!! Dc5 wont go into gear
When mine did this the clutch was bad
Old May 28, 2014 | 07:58 AM
mustclime's Avatar
does the slave cyclinder move the throwout arm when the clutch is pressed?...sounds like a slave or clutch master cyclinder is blown..........most times, thats the problem. If the clutch just stops working without lots of noise and braking sounds beforhand...its ether the master or slave..........most times I tell people to just replace both because if one goes, the other is not
far behind.
on a side note..........most people frget the clutch master cyclinder can be adjusted from under the dash.......
Old May 28, 2014 | 07:59 AM
mustclime's Avatar
you got owned.......this is not how clutches fail.
Old May 29, 2014 | 07:20 AM
meeka661's Avatar
far behind.
That is music to my ears. its currently in the shop right now the guy is supposed to call me today and let me know. thanks for the replies!
Old May 29, 2014 | 07:30 AM
mustclime's Avatar
worked is a shop for years.......can't tell you how many times I saw people get hit for a new clutch then it was a slave, master or clutch cable( some cars use cables ot linkages).........if the shop tells you its a clutch.......check it before you have them replacee the whole mess...
Old May 30, 2014 | 06:28 AM
meeka661's Avatar
yeah that's why i didn't want to take it to a shop at first. But It was the slave cylinder, I went ahead and told him to change the master too. right away he told me it wasn't the clutch so he cant go back on that. thanks man.
Old May 30, 2014 | 04:56 PM
NHBP-TypeS's Avatar
Lol owned.. Funny, mine did this after the slave cylinder was just replaced. Then had this problem, changed clutch and haven't had a problem since.. I was simply just stating what i had experienced when havingr this problem..
Not like I was saying it was the for sure the clutch and only the clutch
When my slave cylinder when bad it wouldn't go into gear. And had the same problem when my clutch went bad. So I experienced this problem when both parts went bad
Old May 31, 2014 | 07:30 AM
meeka661's Avatar
Are you guys ready for it? ******* PLOT TWIST!... I pick my car up from the shop yesterday and start driving home everythings fine then all of a sudden I cant shift to 2nd gear. so I pull over and same problem. wont go into gear. I turn it off turn it back on goes into gear but just revs now and doesn't go forward. So pissed right now im about to call the shop right now. So what you guys think? clutch? oh and it wont go into 5th or 6th gear.
Old May 31, 2014 | 08:51 AM
mustclime's Avatar
think they may have done a crap job of bleeding or you got a crap part....the problems with taking your car to a shop is you never know what they did...did they get a honda part or a crap remake from china? Was the car heat cycled before they handed it over to you...was it freash brake fluid or crap that has been sitting on the shelf for years opened.......... you never know for sure unless you stand over them and watch( they hate this btw)......thats why I took the time to learn how to do this stuff .......
open the hood.....and have a friend depress the clutch peddle and see if the slave is moving........lord forbid people look under the hood
as for instant clutch failor....there are only a couple of ways that can happen..
1) the friction disks can shear off the clutch disk.....when this happens you get a bunch of sliping and squeeling
2) the pressure plate springs fail...99.9% of the time something brakes and you get noise like loose change in your bell houseing.....
3) the throw out bushing or arm fail.....99.9% time things brake off and you get the sound of things bouncing around in the bellhouseing....
hope this helps
Old May 31, 2014 | 10:17 AM
meeka661's Avatar
hope this helps
yeah I have a lot of friends with Dc5's and they know what their doing they just didn't have time so I took into the shop I regret it. but today there going to put a clutch in if I can find one. but before they do ill tell them to check the slave. and ill see if I can get the info on the parts the shop put in.
this is very helpful thanks man
Old Jun 1, 2014 | 06:17 AM
mustclime's Avatar
It is a real pain to get all the air out of the system....sometimes it take a couple tries.......
Old Jun 1, 2014 | 10:37 PM
meeka661's Avatar
The clutch was toast. I replaced it everything is all good now. thanks for all the replies once again
Old Jun 2, 2014 | 12:48 PM
NHBP-TypeS's Avatar
Lol hmmm not how a clutch fails uh.?? Lol who got owned.!!?
codybb4
Dec 9, 2008 08:44 AM
old_school_dohcvtec
Oct 4, 2007 09:47 AM
mattmw88
Dec 9, 2006 06:00 AM
candy eg
Jan 11, 2006 08:22 AM
herbalist
Mar 25, 2005 07:59 PM
