crx dpfi to mpfi b20 swap code 4
Old May 26, 2014 | 11:51 AM
TehTaylor's Avatar
Default crx dpfi to mpfi b20 swap code 4
i bought and 89 crx and the wiring was all cut into and messed up so i decided to start fresh. I pulled all the cabin and engine wiring out and found a virgin 90 crx auto and pulled all the wiring from it. I then converted the harness to mpfi and wired the dizzy plug to obd1 because i already had a obd1 dizzy and didnt feel like buying another. I have the motor in and most of everything hooked and it is throwing a code 4. It is idling good enough to were it doesnt die but if you even crack the throttle a hair it wants to die. I have triple checked my wiring lol my nice harness is all cut open. I have swapped 2 known good dizzys and 2 ecus and no change. What all can be throwing this code? I dont know where to go from here.
Old May 27, 2014 | 07:29 AM
4drEF's Avatar
Keyboard Humorist
Default Re: crx dpfi to mpfi b20 swap code 4
Good ECU
Good Distributor
= bad wiring.
DA9Sleeper
Nov 6, 2011 06:57 AM
rebelwolf18
Oct 8, 2009 08:56 AM
Tensa_Zangetsu
Feb 28, 2009 05:12 PM
Dr. D-Series
Oct 29, 2007 08:53 AM
milruner
May 12, 2005 05:15 AM
