Trany M2S4 internals into M2Y4 case
Old May 25, 2014 | 04:27 PM
gmcuajo1's Avatar
Default Trany M2S4 internals into M2Y4 case
Does the M2S4 internals fit into M2Y4 case?
I have an M2S4 which I want to swap to an M2Y4 case, along with the (aftermarket) LSD.
Why? I want the M2S4 ratios but the case is not as good. Also I want to put the LSD that is already in the M2S4 and put new carbon synchros.
Old May 25, 2014 | 05:10 PM
Sparksman's Avatar
Default Re: Trany M2S4 internals into M2Y4 case
So whats wrong with the trans current casing? Is it broke? They should be the same other then gearing. Just take out the gears swap everything including lsd over and rebuild as normal.
Any usdm open diff trans can take a aftermarket LSD.
Old May 25, 2014 | 10:08 PM
gmcuajo1's Avatar
Yes the case is broken on some points and had been welded/"repaired" on some of the rear braket mounting points.
And for the questins, it should work?
Old May 26, 2014 | 03:57 PM
Sparksman's Avatar
Id assume so, Im not going to guarantee because I havent done myself. The LSD can swap for sure. But as for whole gear sets, I dont see why not is what Im saying. But how are you going to do this? Wouldnt be worth taking to a shop, so I hoped you knew what you were doing.
Old Jun 1, 2014 | 05:55 AM
gmcuajo1's Avatar
Email to synchrotec and they replied that the cases are different but the LSD will work. Not other internals.
CTCD5
Transmission & Drivetrain
Nov 1, 2014 09:53 AM
Wh0 Iz UNREAL07
Nov 11, 2010 09:42 AM
1320king
Oct 6, 2008 11:54 PM
andreasofpartridgetrail
Feb 18, 2007 09:19 AM
DR. ON POINT
Aug 14, 2002 06:00 PM
