98, dx hatch swap
Old May 23, 2014 | 03:44 PM
fraxxure's Avatar
Default 98, dx hatch swap
Hey guys, I just bought a 98 DX hatch and being its a d series, I was just wondering what the better swap would be; the b18c1
Or the f20c? - a complete conversion-
Old May 24, 2014 | 09:02 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: 98, dx hatch swap
LS7
Old May 24, 2014 | 09:12 AM
DVDr's Avatar
welcome to the forum fraxxure.
Best thing to do is read through other threads.
Biggest thing will be your budget and intended use.
Options for a simple upgrade are:
turbo current motor. probably will give you best bang for buck and fun if is just a street car
build current motors ( pistons , vitaras or better ) . and run more boost
then the b series swaps, these are pretty bolt in with simple parts.
you will need mounts / motor / tranny / axles / ecu / shifter bars / clutch / pp / flywheel .
What motor is best, depends on your $$ and if you plan to build it up.
B18bs and b20bs are super fun for the buck. then b18cs
Then you could go into the F20c, but I would go straight to a Kseries. But mind you this swap adds a few more bucks ( by bucks I mean thousands ) .
Best of luck with your Civic.
fraxxure
May 24, 2014 11:44 AM
green93hatch
10
Feb 29, 2012 06:54 AM
NHcuban
Feb 13, 2009 12:09 PM
EJ8 GSR-T
12
Jun 7, 2005 11:35 AM
