D16y7 whistle noise at high rpms?
Old May 23, 2014 | 10:40 AM
KhmerPride's Avatar
Default D16y7 whistle noise at high rpms?
I bought a ek hatch with a d16y7 and when I get into around 4500 rpms a whistle noise comes from my engine, does anyone know what is causing this? It sounds pretty cool but I'm just curious what it is. The only thing I notice in the engine is that there is a ipt fuel rail too if that helps, there might be more but I don't know.
Old May 23, 2014 | 11:50 AM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: D16y7 whistle noise at high rpms?
EJ6, not EK.
Does the car have an aftermarket intake?
Old May 24, 2014 | 07:46 AM
KhmerPride's Avatar
No the intake is stock
Old May 24, 2014 | 10:02 AM
Nave43's Avatar
My aftermarket intake whistles at low rpms, but i partially blame that on the cone filter i use (has a second cone in the end piece). Although ive read of some people adjusting there idle screw to make it whistle on purpose. Personally i find it annoying. It reminds me of a vacuum leak.
...actually now that i said that, have you checked for vacuum leaks?
Old May 24, 2014 | 03:49 PM
SpokaneSpeed's Avatar
Sounds like you may have a crack or a tear in the intake piping, or the airbox is not closing/sealing tightly. Could also be a vacuum leak, but you would more than likely hear it at idle as well if it was a vacuum leak - and it would likely bump your idle RPM up as well...
Old May 25, 2014 | 08:29 AM
nickelz34's Avatar
My old d16 used to whistle at the throttle body when giving it gas at a certain rpm check it out . I think it was when it opened and closed inside were butterfly looking thang is .
Old May 25, 2014 | 09:09 AM
Former User's Avatar
Even when revving in neutral?
Old May 25, 2014 | 11:12 AM
KhmerPride's Avatar
where would i look for a vacuum leak?
Old May 25, 2014 | 03:04 PM
nickelz34's Avatar
Mine did in neutral idk about OP
Old May 25, 2014 | 03:13 PM
If the OP's whistle does too, then he has an opportunity to pinpoint the source of the noise using an inexpensive engine stethoscope.
And a vacuum leak would cause a high and hunting idle.
Old May 25, 2014 | 05:20 PM
KhmerPride's Avatar
No whistle noise in neutral, only when I'm smashing and it starts when I get at 5k rpms and it continues as I keep going
Old May 25, 2014 | 05:22 PM
Is it a whistle or squeaking sound?
Old May 25, 2014 | 08:24 PM
KhmerPride's Avatar
it sounds like a whistle, like a whining whistle. Kinda similar to a supercharger sound.
Old May 29, 2014 | 12:03 PM
Nave43's Avatar
BUMP for curiosity sake
stevew84
20
Mar 18, 2008 05:56 AM
vancouverdc4
Jun 20, 2007 08:11 PM
Baron55
May 14, 2007 04:32 PM
ekcivic9
Feb 8, 2006 11:42 AM
casmello
Jan 21, 2005 01:11 PM
