Vss error code isssues
Old May 22, 2014 | 07:42 AM
mr. Grind's Avatar
Default Vss error code isssues
I am consiste nt ly getting a vss error code one my b20 vtec jrsc 1989 dx civic. mechanical speed cable. (busted at the moment)
1. Will replacing the cable get rid of the code.
2. I unplugged the little blue plug on the back of my instrument cluster.. speedo = no code but will that affect my performance since the ecu is expecting a signal.
Ps. P72 obd1 ecu, hondata s200b, obd 0 car.
Old May 22, 2014 | 08:22 AM
4drEF's Avatar
Keyboard Humorist
Default Re: Vss error code isssues
It should.
Old May 22, 2014 | 08:25 AM
JPhilBradley's Avatar
Icon2 Re: Vss error code isssues
Doesn't the ECU look at vehicle speed when deciding to activate VTEC? If so, will the ECU still get its VSS signal with the instrument cluster unplugged?
Old May 22, 2014 | 08:31 AM
4drEF's Avatar
Keyboard Humorist
The blue plug is for automatic seatbelt light on 90/91 clusters. It doesn't carry the VSS signal.
If you DID unplug the correct wire for the speed pulser -OR- if you don't fix your speedo cable (speed pulser is mounted to the back of the speedo and the speedo cable makes it work) then your ECU sill not get VSS signal.
JPil is right - the VeeTAKs won't kick in and, in generals, a lot of things will be wrong with how your ECU operates.
Old May 22, 2014 | 05:04 PM
mr. Grind's Avatar
no ****, that why my car been feeling lethargic after i unplugged that plug on from the back of the cluster. (might have been green will double check). it indeed got rid of my check engine light but car got slower. thank u sir
beatngyou27
26
Nov 8, 2013 06:59 AM
1slowcrx
Engine Management and Tuning
Sep 19, 2010 08:54 PM
SpeedingHatch
Jun 4, 2006 04:13 AM
trojenman183
Mar 15, 2006 06:56 PM
^Sammy]!.
Apr 6, 2003 05:19 PM
