93 Integra ecu in 89 hatch si
Old May 21, 2014 | 08:23 PM
kenneth4g4d's Avatar
Default 93 Integra ecu in 89 hatch si
Im doing a ls swap in my 89 hatchback si. The ecu i currently have is from my 93 DA which used to be a automatic which i swapped to a manual, and all i did was make it read in park for the car. Will this ecu just plug in (once i repin the obd1 plugs on the 89 harness) and work fine?
Old May 21, 2014 | 09:21 PM
jonGSR's Avatar
Default Re: 93 Integra ecu in 89 hatch si
Only if you using the jumper at the ecu connections. You're hatch is obd0, this ecu is obd1.
Old May 22, 2014 | 06:45 PM
yea im wiring in the odb1 plugs on the obd0 harness, using the info from :
https://honda-tech.com/forums/showth...d0+obd1+wiring
im just making sure once that is done i wont have an issue from it being a automatic ecu, cause when u do a auto to manual conversion u have to make it think its in park so it wont give u issues. So im trying to clarify that once that is done (the link above) itll work
Old May 22, 2014 | 10:30 PM
jonGSR's Avatar
You could have bought the harness for like $40 shipped and not had to hack up the wiring at the ecu on the hatch. You never know when a different motor may get swapped into it.
josh_db1
May 11, 2010 08:35 AM
notburton06
Jan 30, 2007 08:08 AM
mawkiemarc
22
Feb 28, 2006 12:21 AM
Mr.DC2TurBo
Nov 15, 2003 03:11 PM
moike
Sep 15, 2003 05:27 PM
