quick question for any chipped ecu gurus
Old May 21, 2014 | 07:38 AM
jshaw23's Avatar
Default quick question for any chipped ecu gurus
I found a guy in my area with a p28 chipped with Neptune, I don't know what to look for to make sure everything is legit. I know if that if I get this I will need the obd2 to obd1 harness but what else would I need to do for this to work?
Old May 22, 2014 | 08:51 AM
crazes's Avatar
Moderator
Default Re: quick question for any chipped ecu gurus
have him send you the model number and s/n to verify its correct. Pictures to verify that the pins are installed correctly.
Old May 22, 2014 | 12:21 PM
Sparksman's Avatar
Neptune uses Moates demon data logger, which should be clearly visible once you pop the cover off. It will also have a usb cord coming from the ecu for a computer. Also verify the serial number with neptune to assure it was not stolen. Like a cell phone once that serial has been reported stolen it cant ever be updated or changed. Which makes it almost useless, unless its kept with the motor it was stolen with.
Old May 23, 2014 | 10:11 AM
jshaw23's Avatar
I'll check that, thanks for the info
Old May 23, 2014 | 04:20 PM
98vtec's Avatar
moderator emeritus
If it was tuned by a dealer, they have the ability to burn it onto a chip. Only way to know is to find a Neptune dealer and have them pull the bin file off the chip. If it's the demon board it will look pretty obvious.
LSVTAK_EK
21
Mar 17, 2012 10:16 AM
big_dong861
Nov 5, 2007 05:49 AM
8_6 luder
Jan 17, 2007 06:09 PM
lv6l
Dec 4, 2005 06:41 PM
